TRX Restoration Project
Re: TRX Restoration Project
Post by Con Rod » Thu Jan 19, 2012 1:09 am
Anyway it is some improvement and having done that I decided to balance the carbs properly.
I had previously used a feeler gauge to get the butterflies lined up pretty well but they felt a little out of balance, so I decided to make a vacuum gauge
Very simply some 10metres of 3mm clear hose, 10ml of oil and a leght of wood.
Procedure is that you run the oil through the hose to the middle, get any bubble out and connect the ends of the hose to the inlets.
Not pretty but very effective.
My first reading was resonable close to balanced:
I turned the screw about 1/4 turn counter clockwise and that sorted it.
Post by Con Rod » Thu Jan 19, 2012 1:17 am
And the screen arrived last night so I put it and the morrors on. All thats left now is to put the badges on and get it blue slipped and registered
devlin
Post by devlin » Thu Jan 19, 2012 3:30 am
Sweet.
Eaxctly where do you place the carb end of the vaccuum gauge?
Post by Con Rod » Thu Jan 19, 2012 4:03 am
You can connect directly to the vacuum plugs on the intake manifold boots here:
Or you can make life a bit easier by connecting to the vacuum hoses which come from the intake manifold boots on cylinders 1 and 2 which are in easy reach on the fuel tap and fuel pump here:
Just make sure you keep both ends of the hose as close as possible to the same length from the middle where the fluid is on your gauge
Post by Con Rod » Thu Jan 19, 2012 1:01 pm
have not put the badges on yet but very happy with the screen I got from Screens for Bikes
Also really glad I decided to paint the inside of the fairing black, with the black resevoir I am pretty happy with the cockpit set up
Dav
Post by Dav » Thu Jan 19, 2012 2:02 pm
Blast thru the national park when its done? 8)
Post by Con Rod » Sun Jan 22, 2012 7:32 am
Blast through the Nasho will have to wait I am afraid. She got blue slipped and registered yesterday but unfortunately I have to wait til January 31st till I can transfer to the full licence so I will be on the Yamaha Zeal till then,
Still, have had a few cheeky spins just to get everything set up..........damn I like this bike,
Stankflapper
Post by Stankflapper » Sun Jan 22, 2012 7:40 am
Job Well done mate =D> =D> =D> =D>
Post by Con Rod » Mon Jan 30, 2012 12:47 pm
Will be droppig into the RTA at lunchtime tomorrow to upgrade my licence so I will finally be able to take her out for a propper spin tomorrow evening.
Just doing some final touches.
I had ordered a clear tail light from a wreckers in the UK which had some LED bulbs. Pretty happy with that as it worked out about AU$40 which is about the same I would have paid for the LED bulbs here by themselves:
Go a pillion seat courtesy of Alextrx850 and also chucked some stickers on the lid I sprayed
Post by alextrx850 » Mon Jan 30, 2012 7:47 pm
Hi Con Rod, what is the switch block on your right clipon for..?
You must be iching to get a go on there, the bike.s come up well,..any other mods in the pipeline ?
Really happy with the electronic speedo..ripper
Post by Con Rod » Mon Jan 30, 2012 9:29 pm
Glad you are happy with the clocks Alex,
the switch block is for heated grips. I have moved it since that photo to tidy up the cockpit area:
Post by dandywarhol » Mon Jan 30, 2012 10:15 pm
HEATED GRIPS?????................. In Sydney!!!!!!!!!!!!!!!!!!!! Ya some kinda poofta?
now if it was Perth (Scotland) I'd understand :wink:
Post by Con Rod » Tue Jan 31, 2012 12:04 am
dandywarhol wrote:HEATED GRIPS?????................. In Sydney!!!!!!!!!!!!!!!!!!!! Ya some kinda poofta?
I am originally from Ireland and before I moved here I just assumed that Australia was always hot. But seriously it gets bloody cold in winter outside of Sydney. Snow and all the rest of it. Brrrrr......I ride all year round so best to be prepared. But I will confess I have gotten a bit soft since I moved here
Post by dandywarhol » Tue Jan 31, 2012 12:30 am
Just yankin' yer chain Con - I'm told these mountains near you are the place to go on a good day?
devlin
Post by devlin » Tue Jan 31, 2012 1:03 am
Bells Line Rd for sure is an awesome ride. At the foot on the mountains is a place called Pramrith....sorry......Penrith (locals will get the joke) it gets down into the -5's quite few times in winter.
