The TRX900 Project kicks off
Post by coxylaad » Tue Sep 26, 2017 10:31 am
Does anyone have an old scrap TRX frame they dont want anymore? I want one to chop up
Post by Mincehead » Tue Sep 26, 2017 11:11 am
YEP, but I aint posting it. Want 50 quid for it. ;)
Post by coxylaad » Tue Sep 26, 2017 11:13 am
where abouts are you based these days mince? I cant keep up :lol:
Racer-unk
Post by Racer-unk » Wed Sep 27, 2017 8:20 am
Best of Luck Coxylaad...give us hope
Post by Mincehead » Thu Sep 28, 2017 9:29 am
coxylaad wrote:where abouts are you based these days mince? I cant keep up :lol:
Now back in West Sussex. :wink:
Post by coxylaad » Thu Sep 28, 2017 9:49 am
christ not very far away then :shock:
Post by Mincehead » Thu Sep 28, 2017 4:08 pm
Just a mere `jaunt`, me n the old Donkey did 1,060 miles last weekend.
Post by coxylaad » Thu Sep 28, 2017 10:27 pm
well there's no going back now.
Popped down to York to pick this little lot up.
It looks like quite a large pile of stuff, but in many ways its more compact that the trx engine. its not as deep front to back by about 30mm, and its not as tall either. Means I should be able to make brackets up for it to fit.
Crucially though its just a fraction too wide at the cylinder head for it to fit between the lower frame tubes. Once I have got this last trackday out the way I will strip the bike back and see how it offers up. I am not totally confident with 'dressing the insides of the frame tube to clearance it. I may have to make a new bottom tube up on one side.
After specifcally asking for a none abs mt09 I now have a full setup for a yamaha tracer, which comes with ABS and traction control. neither of which I want. I am going to see if I can get it flash written out of the ecu.
other than that all good though, the engine is relatively unmarked and has 6600 miles on it.
Post by cobbadiggabuddyblooo » Fri Sep 29, 2017 12:57 am
If you choose to modify the frame and chop and weld in a new bottom rail to mount it, Get a measurement parallel from the LHS engine mount position on the head to the drive sprocket centre.
Do the same on a trx motor as the 40mm offset you need to fit into the frame can work to an advantage on sprocket alignment on which bottom rail to replace.
Post by Mincehead » Fri Sep 29, 2017 6:43 am
Pay a lot of money for that motor Coxy, 500 quid=ish?
Post by coxylaad » Fri Sep 29, 2017 8:20 am
yes cobba, the drive sprocket will govern where the engine sits in the frame.
Mince if you can get me an mt09 engine setup like that for 500 quid I'll have 3 of them please! :lol:
SDN
Post by SDN » Tue Oct 03, 2017 2:08 pm
My mate lunched his MT10 engine, reckons he got a used replacement engine for £1500, which I thought was good value - course he could have been lying
SDN
Post by SDN » Tue Oct 03, 2017 2:14 pm
Oh yes and by the way looking forward to seeing you shoe horn an MT09 engine into your TRX - good luck and keep us all posted!
Post by coxylaad » Tue Oct 10, 2017 10:25 pm
Last ever track session on the TRX in its current form.
it was a lot of fun
https://www.youtube.com/watch?v=YkMHnmdTLg4&t=
enjoy!
Post by dandywarhol » Wed Oct 11, 2017 11:23 am
Good one. Consistent lines!
Only using 3 gears (apart from moving off)? Have you considered downgearing it and using the upper ratios which are closer spaced? #just thinkin'
