Xenon conversion, something went wrong, working fine now!
- Greg
Re: Xenon conversion, something went wrong, working fine now!
Tidy mounting ... well done!
- steve speed
looks like i may have to send mine back ,,it will not switch to high beam ,,the two wires that go to the electro magnet on the back of the bulb are giving 3v ,there is continuity at the electro magnet so its not that , i think its not getting enough volts to it ,,very bright though ,,
- Trixz
Bummer, I know the feeling of returning, waiting and then hoping that it will be o.k. with the new onesteve speed wrote:looks like i may have to send mine back ,,it will not switch to high beam ,,the two wires that go to the electro magnet on the back of the bulb are giving 3v ,there is continuity at the electro magnet so its not that , i think its not getting enough volts to it ,,very bright though ,,
And indeed, as said, VERY bright
- Trixz
Thanks! Yep, I'm very pleasedGreg wrote:Tidy mounting ... well done!
- Number8
as far as im concerned hid xennons should be standard onever vehicle!!!
god there so much better than normal fillament bulbs!
Ive had them on almost all of my bikes
only problem is due to styling and good lookes ove good headlighs on modern cars/bikes alot of them now the rear refletor casts the beam pattern not the front glass/plastic thingy which is just a clear peice of plastic and there the ones that cant be used with hid's basicaly cos fillament bulbs have a black coating on the end to stop light comeing out the end, and hid's dont , so basically blind other drivers
ive got one on my trx , but thats got a totally different front end (triumph 675) thats got H7 bulbs in projector lights so there shit hot with hid's , projector lights are the best to use with hid's
Booo
AHAHAH
Ignore my spelling and grammar , theres a reason i ride a bike for a living !
AHAHAH
- Trixz
@ number8
I share your opinion, I'm not fond of vehicles with blinding lights behind me or coming straight at me.
So for my REX I've adjusted the light a bit down to the road, because the rays of light from the HID still give enough visibility in this situation IMHO
- Greg
Hi Steve...
If you've got enough current to fire the ballast there shouldn't be any issue at all at the 'solenoid' plug! Have you tried unplugging the little plug when the light's on - I'm guessing that if there's current all the time to the electromagnet then it won't switch, so maybe there's a wiring issue. Again - I'm guessing that the no current state would put it on dip beam - what beam are you stuck on?
G
G
- steve speed
hi Greg,,, when i put the meter on the bit that works the solenoid ,,the connector , i only get 0.7 of a volt ,then as i switch it to dip or main beam it momentarilly jumps in voltage to about 3 volts then drops back to 0.7 volts so what happens is that nether end of the solenoid is energized so as the bike runs the bulb can slide to any end ,which is usually high beam ,,,i personally feel its the control box that's faulty,, the solenoid has continuity in the wiring so its not the bulb , theres just not enough volts to energize the solenoid,,, the control box is potted so i cant test any part of it ,,is yours working ok ??
- Greg
Hi Steve ..
Yes, mine's fine - I'm sorry but I can't get to the wiring on the Beemer without taking half an acre of plastic off first...
I do have a twin relay harness that I got as part of the kit waiting to be fitted to my VW - you're more than welcome to borrow it to try with your kit.. let me know soonish though as I'm off for a couple of weeks from Friday..
- Tarwetijger
Exactly! That's why I have thisNumber8 wrote:8< ... projector lights are the best to use with hid's
The HID kit just came in today. The components are so tiny! I've also HID in the car, but those are huge.
- steve speed
thanks Greg for the offer but i have now sent the lot back to china for replacement
,,i was in too minds weather to buy another one for spares but now Ive got a nagging doubt about reliability of there units ,,,so i will give it another go when it returns ,,,,fooking bright though,,,and thanks again for the offer
- Number8
spot on, and a perfect fit for the trxTarwetijger wrote:Exactly! That's why I have thisNumber8 wrote:8< ... projector lights are the best to use with hid's
oh and the new "ultra slim" ballasts are tiny compared the older original ones , just got a set for my vfr
oh and a comment about the telescopic H4 bulbs , the ones that move back and forth, if u compare the position of the filament of a stock h4 bulb to these there not exactly in the same place on either dip or main beam , so it may bugger up ya beam pattern , be careful they dont always work !!
H4 always was a compromise and built to a price when there were released , why do ya think alot of manufacturers are moving away from them
Booo
AHAHAH
AHAHAH
- Greg
Tarty...
That light unit - one reflector and one projector? What's it from? I've got a twin projector unit from a 400 I think, but am buggered if I'm spending almost £40.00 on two bulbs for it ...
FZR 600, i had one before changing to the 400 one (red rings)Greg wrote:Tarty...
- Tarwetijger
FZR600 indeed. Main light is a H1 bulb with projector, high beam is H3. I think I will fit philips bluevision for high beam.
A FZR400RR/SP headlight would be great, but those are hard to find!
