All Advice welcome with my impending TRX strip and rebuild
Re: All Advice welcome with my impending TRX strip and rebui
Post by cobbadiggabuddyblooo » Tue Mar 05, 2013 5:43 am
phuk72 wrote:
cobbadiggabuddyblooo wrote:Did you have a std can on your Akrapovic system at some stage Andy ??? If so what the difference with the devil can....
Yes I did ;) Aboout 4db and 2hp at the top end
Can you remember the outlet size on the Devil can phuk ??? The Akra can on the full system is fairly heavy compared to the alloy can I had on the previous 2 into 1 and only 50mm and fairly quite in my opinion
Post by phuk72 » Tue Mar 05, 2013 12:14 pm
I have a feeling it was 60mm - whatever it is it's a larger bore than the Akra pipework
Post by misterdimwiddy » Tue Mar 05, 2013 1:38 pm
phuk72 wrote:I have a feeling it was 60mm - whatever it is it's a larger bore than the Akra pipework
I will measure up tnt and let you know the dims of the Devil can.
This is starting to confuse me; I now own the Akra headers + Devil (fitted to the red and white TRX) can that did belong to Pete.
Phil
Post by misterdimwiddy » Tue Mar 05, 2013 8:25 pm
OD of Akra headers is 52.5mm.
OD of Devil can header location is 54mm.
When I next take the can off I will measure the ID if it is of use to anyone.
It's a great system (very light) but loud at 104dB. 98dB with a killer in place.
Will see what difference the dB killer makes to HP when I get it on a dyno in a month or so.
Phil
Post by phuk72 » Wed Mar 06, 2013 9:52 am
misterdimwiddy wrote:OD of Akra headers is 52.5mm.
Phil
that Devil can has been tapered to fit Akra pipework - as standard it is nearer 60mm IIRC
