Rod.s
by Rod.s » Sat Jan 05, 2013 1:41 am
cobbadiggabuddyblooo wrote:http://www.racetech.com/
Go to the spring rate section and click on the calculate spring rate when set up for TRX and your weight ..wet weight (full tank of fuel) of a TRX is 204 KG std... also the std cans weigh around 6kg each too so if you have changed them that may save you some weight...
Shit i must be a fat barstool the calculator recommends, twice the standard weight!!
by Con Rod » Sat Jan 05, 2013 2:07 am
I am .85, most people seem to be about .9, I am guessing you are about 100kg so not that bad.
From what I have read the recommended spring weights are a a bit on the heavy side so you might be better to round down
ritza
by ritza » Fri Jan 11, 2013 11:47 am
i'de open door 3 barry...
rbaron25
by rbaron25 » Fri Jan 11, 2013 1:32 pm
Nah he's a fat bastard he will need the heavy duty twin coilovers for the mack...
I didn't see you...
Cause you didn't bloody look!
