NEED MORE TOP END!!!
Re: NEED MORE TOP END!!!
Post by trixynut » Thu Apr 05, 2012 11:03 pm
This is my dyno curve from my old bike which had bigbore 2 into 2 system with freeflowing cans and FCR carbs on a standard engine, just like yours.
Chart doesnt show RPM unfortunately, but the big drop-off in each gear is where it hits the limiter, so you can see you should have a pretty linear power delivery in each gear, but best torque and power is up to 7.5k rpm like KW says.
winder
Post by winder » Sat Apr 07, 2012 7:51 pm
Hi, i have spent the past two seasons racing a TRX in UK Thuderbikes (have a look at TRX Eligible For BEMSEE Thunderbikes in the Bike Racing section on this forum). A couple of quick fixes would be gearing, i used 15-42 at Cadwell and the extra breather mod made it rev up to the limiter quicker. P.S. you should be racing it in Thunderbikes where it will be more competitive :wink:
winder
Post by winder » Sat Apr 07, 2012 7:58 pm
Another pic before the big Snett blow up!
