Tank leaking fuel when off the bike
Re: Tank leaking fuel when off the bike
Post by dixonj » Wed Aug 31, 2011 2:03 pm
HolerTogni wrote:Hi Kenny!
Kenny wrote:Do a search for my tap mod its very simple and works 100% no more vac tap needed and no more dribbles.
How 'bout a link to your mod - a search for "fuel tap mod" did not bring the hoped for result ...
Thanks!
Resultless greetings from Munich!
Here is the info on Kennys fuel tap mod
Hi Its actually very simple I removed the spring from the vaccum diaphram and replaced it with washers to make sure the o-ring seal sealed the back part of the tap then reassembled the vaccum side. I then removed the tap side retainer ring with the ON-PRIME-RES and simply rotated it 90 degrees clockwise so now ON is forward OFF is down and RES is backwards JOB done it really is that simple.
Here are some photos of a fuel tap mod that I have done today
1st remove vacum spring
2nd replce the spring with washers or a 5mm spacer
3rd file off the lug
this is the position for fuel on
reserve
and finally the off position
Kenny
Post by Kenny » Wed Aug 31, 2011 6:35 pm
Nice job on the pics there dixonj :D Although I didnt file the tab off and rotated my face plate 90 degrees so I still had a stop so I cant over rotate the tap lever. :wink:
HolerTogni
Post by HolerTogni » Thu Sep 01, 2011 1:46 pm
Hi dixonj and Kenny!
Thanks for showing / sharing the info!
Appreciated greetings from Munich!
(Somehow I manage it that all my sentences end with an exclamation mark!)
rct
Post by rct » Thu Oct 11, 2012 12:35 pm
about the spacer dimentions, can i ask is the total length of the spacer. is it 5mm or do you have to make sure that it sticks up 5mm from the lip so it would be over 5mm in length?
sorry but i could not determin the correct dimentions from your photo.
many thanks RCT
