Taking off, like, real fast
Dash
Re: Taking off, like, real fast
Post by Dash » Sun Oct 19, 2008 4:22 pm
well, the clutchless upshifting is pretty neat. but only between 1 and 2 I feel a yank when I do a clutchless upshift. I take it that is the neutral you have to go past?
What`s that coming over the hill? Is it a T-ReX, is it a T-ReX?
Currently riding the TRX on Boris Jeltsin mode...
Post by cobbadiggabuddyblooo » Sun Oct 19, 2008 9:58 pm
Hey dash..Just have a good feed of fruit and utilise the brown bugle with a lighter to ignite and let the afterburner do its work. save mounting anything and more power to weight
dfh
Post by dfh » Mon Oct 20, 2008 12:28 am
Dash wrote: just yank it all the way to 9k and then shift? or change gears earlier? :dontknow:
Yank it all the way?.... would'nt recommend that :jerk:... well when riding the bike at least.... :roll:
..... and seriously? If its a stock bike short shift from 1st to second ' cos first has a short speed range & the gear change across neutral is a clunky one. Run the remaining gears up to 7500rpm ( peak power on a stocker) and the gear change will drop you to 5500rpm, just before peak torque and primed for the drive up to peak power again. Unless you have made serious mods to the engine - the full house of flatslides, cams, pistons/big bore, full systems etc - the TRX power & torque curves drop off very fast after 7500rpm so over revving is pointless, surf the torque instead.
Oddly enough I run the ever popular 17/41 gearing cos it makes part throttle take offs around town more pleasant, but on track days ( now infrequent :cry: ) found the longer gearing made for better drive once rolling. Should change back to the 17/39 as I now live in Adelaide and no longer have one & a half hours of suburban sprawl to trawl through to get to the riders roads .. =D> Very happy to exchange the traffic light GP's for Adelaide Hills.. :D
DFH
Dash
Post by Dash » Mon Oct 20, 2008 10:08 am
ok, so the clunk and yank when upshifting from 1 to 2 is normal. yamaha huh? :roll:
maybe the clutchless upshifting will give me the edge I need to win from my brother`s bikes [-o<
idl1975
Post by idl1975 » Mon Oct 20, 2008 10:20 am
Dash wrote:Question: what is the best method to get the best acceleration on a TRX? :roll:
so let`s hear it: how do you people sprint against other bikes or (ignorant) car drivers? :ride:
What I read in PB (when John Robinson was technical editor!) was that you get the best results by changing up at a point which will put you at or just under peak torque in the next gear. On most bikes this is coincidentally at or about peak power, which on a stock TRX is something like 7200 (7500?). So you basically ride peak torque to peak power.
'04 Aprilia Tuono Fighter
'00 Scooby Sport Wagon
'76 TY250.
