by all means have a go if your confident and you have the Manuel but you must be able to measure accurately and have a torque wrench that will be suitable,,and yes if you get it wrong you can feck the head upinept wrote:Once I've checked the clearances, would you recommend getting a pro to adjust them or give it a go myself?youngy wrote:Checking clearances isn't too difficult, adjusting them is a pain.
Is there any major damage I can cause if I get it wrong?
Normal engine temp & valve clearences?
- steve speed
IMO, and that is all, I would not trust a dealer to do it right. I have seen (and have one in my garage) 3 engines that have been serviced by dealers and incorrectly re-assembled.
It goes deeper than just the head being knackered.
If the cam caps are overtightened, or the cams are not sufficiently lubricated, or the oil not bled properly on re-assembly then what tends to happen is that the inlet cam siezes after the engine warms up. This stops the exhaust cam rotating, but the extra mass and inertia of the crank keeps the crank rotating. This strips the timing gear teeth from the crank and of course bends a few valves.
The valves are repairable. If you're lucky the damage to the cam journals is minor, but you've no crank left. The timing gear is machined into the billet of the crank, not shrunk on like all the other gears on it.
This is why you see alot of TRX's and TDM's in good shape being broken for parts - shite dealer servicing, for which you're paying £300 (?) plus.
If you have a dealer service the bike, make sure the grease monkey knows what he's doing. My bet is he won't. You'll pay out a shedload of cash, and you might not even make it home. Then you have to prove the dealer did it wrong........etc etc
Do it yourself. Take your time. Do it right. Make sure the cams can be rotated back and forth by hand when the caps are bolted down to 10Nm - no more. Use a good quality torque wrench. Put shitloads of oil on the cams, caps, buckets, shims - everywhere. Learn about how that motor goes together.
- billy budge
- Tarwetijger
- Tarwetijger
Hmm, looks like Yamaha says that with every 5-valve engine.youngy wrote:Yamaha say every 26k miles or 42k km.
42k km is also the target for the YZF, but I've checked valves every winter (because I ride some trackdays with it) and every time I had to adjust a couple. And I'm not even close to 42k km/yr.
- inept
Thanks for the info bud, I have the haynes liebook, decent torque wrench and plenty of beer so I'll give it a crack.youngy wrote:Do it yourself. Take your time. Do it right. Make sure the cams can be rotated back and forth by hand when the caps are bolted down to 10Nm - no more. Use a good quality torque wrench. Put shitloads of oil on the cams, caps, buckets, shims - everywhere. Learn about how that motor goes together.
- inept
This is my single greatest fear. I've striped an oil filter cover bolt before (Virago 535) and even with a Heli-coil it never really sealed properly again. Hate it to happen to a head boltTarwetijger wrote:Just did the valves of my YZF and ruined the thread of the last bolt I was fastening (yes, I used a torque wrench), so I'm not looking forward to it.
- Tarwetijger
Look in the downloads section of this site. There may be something there that's better than the Haynes.inept wrote:This is my single greatest fear. I've striped an oil filter cover bolt before (Virago 535) and even with a Heli-coil it never really sealed properly again. Hate it to happen to a head boltTarwetijger wrote:Just did the valves of my YZF and ruined the thread of the last bolt I was fastening (yes, I used a torque wrench), so I'm not looking forward to it.
Like watches and mobile phones, you can never have enough!.kenmore wrote:Peice of piss compared to what?.I,ve owned the following bikes
1)Honda 50 step through
2)Kawasaki KX125
3)Honda CR125 Elsinore
4)Yamaha RD350(Had 2 of these )
5)Yamaha RD400
6)Honda 350 Twin
7)Triumph Daytona 500
8)Yamaha RD250LC
9)Suzuki PE250
10)SuzukiTM400
11)Yamaha XS650B
12)Suzuki GT750 Waterbottle
!3)Suzuki TS250EX
14)Kawasaki KLX250
15)Kawasaki Z1R MK11
16)Suzuki GSXR750K
17)Ducati Paso906
18)Ducati750SS
19)Yamaha FZR1000
20)Suzuki 750 Intruder(It was cheep at the time)
21)Yamaha WR450F
I,ve missed some bikes but as you can see I,ve owned a few and think that I changed the plugs on most of these bikes at some time whilst I owned them,and still say that to change the plugs on Trixie was not easy.
Maybe I did it the hard way,but I did follow the instuctions in the workshop manual.
- billy budge
Just to go back onto the temp subject again, could using a different non specific trx sensor/sender and guage cause the bike to run hotter???
I played about with a guage usually made for kit cars and the like from etb instruments and it had to use its own sensor and i noticed it seemed to run alot hotter with it, only on the road 10 mins from cold start and it would be on the 80+ degree mark and the rad hoses etc did feel unusually hot. This bothers me as with the standard clocks and sensor and as most people say i never saw it move past the 65 degree mark, apart from traffic dodging in down town valencia and the like!!!
Would like to know if a different setup could cause overheating probs or not, apart from that the only other thing ive done engine wise was take the cases off to be polished...couldnt see owt going back on could cause this prob???
