ignition coil tap for vapor
- Kevtrx849
- Moderator
Previously had it wrapped around the right hand spark lead 5 times tightly. Now have it wrapped 4 times and the bared end shoved down the boot about 10 mm. By boot i mean the rubber sleeve over the spark lead. Shows minimal fluctuation at idle and holds revs cleanly up to 5000 (haven't tried higher yet) where my first gear change indicator cuts in.
( HENRY FORD )
( HENRY FORD )
- pwmotorsports
