Homers TRX900 build.
wreckage
Re: Homers TRX900 build.
Post by wreckage » Sat Mar 23, 2024 4:44 am
How to add images to posts
https://cantonbecker.com/etcetera/2014/ ... ox-images/
Article on this forum somewhere:
1. right-click on the file that is in your Dropbox folder on your PC
2. Copy Dropbox Link to clipboard
3. replace string at end of URL: ?dl=0 with ?raw=1
4. Surround/enclose with [ img ] and [ /img ] tags on the forum.
METHOD 2:
Use the following method for Google Drive: https://gdurl.com/
:riding:
tdrx21
Post by tdrx21 » Wed Apr 17, 2024 5:36 pm
I managed to get around the front sprocket offset issue in another way if anyone is interested.
I found that an RVF750 sprocket uses the same spline, is 525 pitch and is substantially wider (14.5mm) than the TDM sprocket (10.8mn) at the centre.
I machined a 4mm deep counterbore in one side of the sprocket, which left a 4mm boss on the other side of the sprocket.
It now sits 6mm inwards from where the original one was.
HolerTogni
Post by HolerTogni » Thu Apr 18, 2024 3:06 pm
Hi tdrx21!
Thanks for telling us an alternative way for aligning the front sprocket with a TDM 900 engine in.
"Appreciating your post" - greets from Munich!
tdrx21
Post by tdrx21 » Thu Apr 18, 2024 7:07 pm
No problem,
Hopefully the information will be useful for for anyone doing the same engine swap.
In order to use the standard nut - I also made a 3mm thick spacer to go between the sprocket & the tab washer.
An M30 washer would be good enough to use for anybody that doesn't have access to to a lathe though.
