These are the Kent Cams "Yam 9" grind that "everybody" gets and uses in a Trx.I think they'll prove to be just the ticket for my quest for a packed mid-range.
While I'm here I thought I'd try to clear up the issue of the quoted timing figures.I have read on the forum that the timing figures for this cam are, Inlet 15/45 and Exh 49/11 (and so they are) but they cannot be directly compared to the std Trx quoted figures of 29/59 inlet and 49/11.
The Yamaha cam durations are quoted "seat to seat" whilst the Kent cam durations are quoted at .040" lift.
If this were not the case the numbers would imply that the Kent inlet cam has only 240 degrees duration (15+180+45) compared to the std Yamaha cam with 268 degrees (29+180+59).Clearly nonsense
After speaking to the designer of the Kent cams,I established that the "seat to seat" figures for this grind are in fact; Inlet 45/75 and Exh 79/41 making 300 degrees duration for both inlet and exhaust
This is some 32 degrees more inlet duration and 42 more exhaust duration than standard.
These cams also have a lift of 0.43mm more for inlet and 0.28mm more for exhaust.
Can't wait to have completed head to fit them to
