Flapper Goes Cafe
Stankflapper
Re: Flapper Goes Cafe
Post by Stankflapper » Sun Jul 10, 2011 7:59 pm
Marty,Standard springs in the front till I see how it handles and the rear is the Fj1300, which is 105 – 160 N/mm. Hope this helps. Anyone know the front fork oil capacity yet?
Kevtrx849
Moderator
Post by Kevtrx849 » Mon Jul 11, 2011 12:37 am
Don't know the volume of oil but i found that 130mm air gap with the springs out and compressed worked pretty well with the standard gear (many moons ago)
( HENRY FORD )
Marty Moose
Post by Marty Moose » Mon Jul 11, 2011 6:29 am
130mm is the std height its way to low for the std springs unless you weigh as much a midgey :) Std springs I'd start at 100mm air gap and be prepared to go higher.
MM
Stankflapper
Post by Stankflapper » Mon Jul 11, 2011 8:39 am
Knocked up a quick Stainless frame filler panel.. What is your opinion??? To run with it,,, or leave it exposed under the seat??
Marty Moose
Post by Marty Moose » Mon Jul 11, 2011 10:57 am
Looks neat maybe a bit slabby! I guess when you get the rest of the body on you will get a bit more of an accurate idea. I do like the white frame and black engine better than the local market ones.
MM
Stankflapper
Post by Stankflapper » Mon Jul 11, 2011 11:07 am
Thanks Marty, after walking around it a few times, my thoughts are not to cover the beautiful Trellis frame and to scrap the filler panel idea. I have removed the frame now and will start to cut it up and get it powder coated, you like the white hey mate, well I am just going to go through the colour chart at the coaters and see what might look better, at this point I am leaning toward silver. The Cams looked just fine once I had a good look around in the top of the engine.. This is how she sits now.
SDN
Post by SDN » Mon Jul 11, 2011 3:31 pm
IMHO silver frame looks the best, alos prefer silver engine to black
Kevtrx849
Moderator
Post by Kevtrx849 » Mon Jul 11, 2011 9:59 pm
Marty Moose wrote:130mm is the std height its way to low for the std springs unless you weigh as much a midgey :) Std springs I'd start at 100mm air gap and be prepared to go higher.
MM
Yeah your right, forgot that his is the import model with softer springs.
( HENRY FORD )
Marty Moose
Post by Marty Moose » Tue Jul 12, 2011 12:32 am
MM
Even the non imports with 0.75's in are way undersprung for most, many bikes of that era are.
cal
Post by cal » Tue Jul 12, 2011 12:53 am
If youve not already done them its 485ml 10w standard springs (uk model)
Cal
NWS870R
Post by NWS870R » Tue Jul 12, 2011 1:12 am
I thought it was the view on my PC to start with but before you strip the frame & get it all powder coated after modding - have you noticed that the rear sub-frame has a bend in the l/h side? It might be an optical illusion but the main rail that passes under the riders seat appears to have a 'dip' in it? Hope i'm wrong but not a big deal to sort if done before paying for powder coating.
With regards to the frame colour it depends on what your final paint scheme will be i guess? I tend to think the original frame looks good in a high gloss red but depends on what you'll be bolting around it?
Stankflapper
Post by Stankflapper » Tue Jul 12, 2011 3:32 am
Sort of past the point of no return now.
Stankflapper
Post by Stankflapper » Tue Jul 12, 2011 3:41 am
NWS870R wrote:I thought it was the view on my PC to start with but before you strip the frame & get it all powder coated after modding - have you noticed that the rear sub-frame has a bend in the l/h side? It might be an optical illusion but the main rail that passes under the riders seat appears to have a 'dip' in it? Hope i'm wrong but not a big deal to sort if done before paying for powder coating.
Nothing wrong with your eyes or your PC mate, that rail had a clout at some stage of its life, what surprised me was that it only needed a very mild belt with a piece of wood to straighten it again. Shit the frames at the rear are weak!
I have had several Ducati`s in the past, so I am over the Gloss red scene just at this stage of my life. I just come back from our local powder coater and looked through his colour chart ,, the silver still does do it for me.
Stankflapper
Post by Stankflapper » Wed Jul 13, 2011 5:05 am
Had the frame and tappet cover media blasted today. So now just a final check over before it goes to the Powder coaters.
twig
Post by twig » Wed Jul 13, 2011 7:44 am
There is a good reason you dont see my head on the website and if you saw me you would see why. But if you do want a peak have a look at this YouTube of a build we have just finished. http://www.youtube.com/watch?v=YcI633X-M2w
Cheers Twig
Twig
