well to start max power was 72.57 max torque 52.49
after adjustment max power 77.88 max torque 54.90
i am distraught
As other says, 77,88 could very well be just right...i think i guessed 79??dillthedog wrote:tears all the way home![]()
i am distraught
I really doubt that FCR´s and acra full would give 23hp over bog standard....sounds as a crank number as mine are....does not matter in the case but i think that the number he got is a realistic number on the rearwheel (What factory pro call true HP)trixynut wrote:There is NO WAY fcr's and an acrapovic full system will show those kinda figures: something is wrong, either dyno or major set-up trouble. I've got fcrs and a renegade full system, nothing else, and power is 89bhp at the rear wheel, and the bike was noticably more powerful after I fitted them. Post up the chart if you can: be interesting to see what type of dyno it was too.
Other than tourque and hp should meet a bit higher i think it´s fine...tourque directly up there and holds fine....HP almost linear (although you can see he used smoothing 5)...cheesie wrote:cant realy see it good did you ask what jets needle pos ect they used
Exactly! The ONLY relevant figure is the difference between your baseline and your modified figure on the same dyno AND in the same atmospheric conditions. Sure, there should be a true HP figure somewhere, but dynos don't usually show that with any signficant degree of accuracy. However, unless the dyno's very broken, it should be calibrated to itself, and hence back to back figures should show what your changes achieve. So you should only be disappointed if the comparative figures show same or lower modified numbers or, perhaps more usefully, a net loss of "area-under-curve".youngy wrote:i'd agree with cheesie regarding torque.
the only way to compare figures between bikes is to put them on the same dyno.
