1. Get all the parts you need.
Oil Filter : 4X7-13440-01
Oil pump cover gasket : 3VD-15458-00
Oil filter housing large O ring: 93210-64297
Oil filter housing small O ring: 93210-12790
Sump plug crush washer: 214-11198-01
2. Put the bike on a paddock stand. Warm the bike up for 5 - 10 mins. Remove the oil tank bolt (pictured) and allow oil to drain. (I got about 3 litres of oil drain from the oil tank)
3. Remove the oil sump bolt (pictured) and allow to drain.
4. Undo the oil filter cover and remove. Be careful when letting this go not to move away to quickly and drop the filter or small O ring and spacer in the drained oil, like I always manage to do
5. Whilst waiting for the remaining old oil to drip out soak your new filter in the new oil. This is supposed to help avoid oil starvation when you fire her up afterwards.
6. Put the the new filter in, refit the small spacer and O ring and then refit all the bolts.
The next point is just what I have found works best for me.
7. Fill with three litres of oil and start up the bike for 10 or 15 seconds. Turn off and add the remaining oil. I have found that I just make a big mess if I try and fill all the oil in one go.
There you go, easy as. Add your tips, or comment on my glaring mistakes below
