no neutral or rear brake light!!!!
neilb10000
Post by neilb10000 » Fri Mar 28, 2008 7:53 am
Hi,i was just wondering if anybody can help me?i`ve recently stripped my TRX and on putting it back together i`ve now got no neutral or rear brake light.
Do you think it could be a bad earth or have i got some connectors on the loom mixed up?your help is greatly appreciated,Thanks. :D
Re: no neutral or rear brake light!!!!
Post by youngy » Fri Mar 28, 2008 11:03 am
Not knowing how much you've stripped I could well be barking up the wrong tree but I had a similar thing where I'd got two connectors crossed over under the airbox. I think there were two 6 way blocks that I'd swapped.
neilb10000
Post by neilb10000 » Sat Mar 29, 2008 7:28 am
Thanks youngy,i took the frame off to clean it up and repaint it.Will have a play with the connections under the airbox.
neilb10000
Post by neilb10000 » Tue Apr 01, 2008 9:38 am
Sorted!!!Tank up,airbox off(again)checked the connectors...5 minutes later.....YEEEEE-HAAAAA!!!!!
Thanks Mr.Young,your a top man!!! =D>
Post by youngy » Tue Apr 01, 2008 10:25 am
No problm Neil - glad to be of service.
