R6 Forks, are they worth it?
Steve
Post by Steve » Sat Oct 06, 2007 4:03 pm
Hey all,
done a load of searching but couldnt find the answer im after, so are R6 forks worth fitting?
I did change the seals etc 2 month back on the std forks and used 10w oil and a bit more of it which has made things feel a bit nicer but theres some close by well forks/tcat wheel/discs/muddy for £140 whaddya say guys 'n' gals.
Red 97' Rex + Black/bronze '53 Falco
kebab19
Post by kebab19 » Sat Oct 06, 2007 7:15 pm
I nearly went for R6 forks, but in the end got a pair of Thundercat / YZF600 ones which appeared on Fleabay.
The Yahoo TRX mailing list has a couple of people who have fitted them and think they are a vast improvement over standard.
I think the biggest hassle is that the R6 reads the speedo drive from the front sprocket, so you'll have to grind away some of the lower fork stanchion to make room for the TRX speedo drive.
Post by trixynut » Sat Oct 06, 2007 8:00 pm
Seen a trx or two with them fitted: can use the same yokes. Aren't they cartridges inside, so better?
Here you go....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :B:SS:UK:1
...make this guy an offer for the complete front end!!
Steve
Post by Steve » Sat Oct 06, 2007 8:36 pm
Thats the guy i had in mind, bit miffed i didnt spot the bike 1st £620 he paid for it :shock: - woulda just dropped my lump in and away i go :D
espesh as i fancy the scorpions too and my paintworks gettin a bit sad - that orrible dull orangey pink that reds go and its a couple of years newer.
He's after £140 for the front end and £150 for the cans which dont sound too bad but knowing what he gave for the whole bike :roll:
Might pay him a visit and see what he says.
Post by Greg » Sat Oct 06, 2007 9:03 pm
Take cash - it's a powerful bargaining tool!
:motard:
kebab19
Post by kebab19 » Sun Oct 07, 2007 12:17 pm
I think the yokes would have to be altered - the R6 fork legs are 43mm diameter as opposed to TRX / Thundercat legs which are 41mm.
Sounds like a good price for the front-end.
Janitor
Post by Max » Sun Oct 07, 2007 1:01 pm
And I'd be willing to bet they are a lot shorter...
Post by Quan-Time » Sun Oct 07, 2007 4:10 pm
r6 forks.. NO.. not even the USD ones.
Get R1 or somethin from a heavier bike.. The zuki TLR ones would be PERFECT as the weight of the bikes is very similar.. but would require a bit more work to make fit.
gl tho :)
i use 2000 R1 blue top USD forks.
Steve
Post by Steve » Sun Oct 07, 2007 4:50 pm
Thanks for the input guys :)
Looks like i'll give em a miss and stick with the std ones for now, perhaps just as well as i'll get to use the set of discs i just got powder coated red and havent fitted yet :oops: along with bluespots and r1 master.
Still hoping for a haggle on the Scorps though.
Cheers.
Post by Quan-Time » Tue Oct 09, 2007 2:32 am
cant remember who, but a few ppl here have re-sprung their forks with quality components. Might be worth a look at.. Will help handling and means you can keep your gear you have now (wheel, disks, etc). which is always a bonus..
Trust me, it gets expensive when you start modding heaps.
dirty trix
Post by dirty trix » Tue Oct 09, 2007 9:27 am
Thinking about the front transplant options versus respringing. Whats on the inside of thundercat forks thats going to make them better than say some aftermarket springs on a trixie front end?
Post by youngy » Tue Oct 09, 2007 10:07 am
ThunderCat and R6 both use cartridge forks - for more tuneable and give better control.
R6 forks are definitely worth it. ThunderCat forks fit straight into the TRX yokes, where R6 don't.
Post by Killerwhale » Tue Oct 09, 2007 10:09 am
dirty trix wrote:Thinking about the front transplant options versus respringing. Whats on the inside of thundercat forks thats going to make them better than say some aftermarket springs on a trixie front end?
Taking from the top/back of my head they add rebound damping....
Please correct me if i´m wrong!
Post by youngy » Tue Oct 09, 2007 10:11 am
Well, ok then....................they add compression damping adjustment, as well as being a cartridge fork.
Post by Killerwhale » Tue Oct 09, 2007 10:23 am
Did not know that there where non USD´s wich where cartridge...
But i might be lost in the english terminology here! :roll:
Could be worth this then:
