Woo fooking hoo - 102.3 bhp !!!!!
				rs1800
errr not quite sure what you mean there, im new to this lol
The gearing is standard and they did check the emulsion tubes which were fine (as well as the fact it idles lovely). I am very happy with how the bike runs and the torque curve seems nice and flat, just wondered how it compared to others in nearer standard setup.
I am quite new to biking (1 year) and am wondering what if anything to do next. perhaps get the suspension sorted? although I'm not aware of any problem.
- Killerwhale
Your HP result should be OK, what gives me a ?....is that it was running fat in standard and they went for a smaller main......rs1800 wrote:errr not quite sure what you mean there, im new to this lol
The gearing is standard and they did check the emulsion tubes which were fine. I am very happy with how the bike runs and the torque curve seems nice and flat, just wondered how it compared to others in nearer standard setup.
If everything was OK and you´ve installed cans and K&N filter you should have to increase the mains.....
Tourqe-a-holic
				rs1800
- Killerwhale
And then it should be anal fairy sex should´t it????rs1800 wrote:exactly, although they didnt seem too bothered
It runs lovely though and the fuel/air mix looks spot on in the chart
We got the winter here and i had the standard settings in the FCR´s....WAY lean....and as i couldn´t go to the maestro i had to go WAY up on the mains...will get fixed soon though.
....with kentcams etc....
If it´s fit.......ride it and forget about it!
Tourqe-a-holic
- Kevtrx849
 - Moderator
79 hp is a good result. Yamaha claimed 76 in standard trim in their brochures. Chances are the suspension has already been sorted as it's usually the first mod made. Might just need fine adjustment to suit your weight/style. Welcome to the site btw.
CYA, Kev.
									CYA, Kev.
( HENRY FORD )
( HENRY FORD )
- burty
Hi rs,
Here's my dyno chart from the Dyno at Renegades. Apart from twin Renegade cans, K&N filter (standard airbox), the Factory pro carb kit the bike is standard. Crank power comes at 80bhp.
Actually it still rides like shit. I still need to play with the jettings. Currently it has the standard 142.5 jets. I've considered going down one size but never actually got round to getting the jets and doing the work. I've tried playing around with all sorts, needle positions, pilot screws, and to be honest I get fed up with the adjust - ride - adjust - ride - adjust - ride, at the end of the day I just ride around the problem.
- burty
BTW we discussed stock BHP in this thread, I think that you will find 79 about par for the course.
http://trx850.motomaniac.net/forum/view ... light=dyno
- Max
 - Janitor
				rs1800
Thanks for info, Ill post pics and stuff up soon.
The bike was completely standard before the exaust and filter so I am sure it has std suspension. I am not a good enough rider to know if the suspension is any good or not (seems ok) but due to the bike being 10 yrs old and having done 17k I assume that the std stuff has worn out? I am quite new to riding and dont want to run before I can walk but I expect to keep the bike for at least a couple of years so should I spend money on this?
				cheesie
- Killerwhale
In my case it was really worn needlejets/emulsion tubes due to city from home to school and back driving in heavy traffic....cheesie wrote:I will have to get mine on a dyno to see what is happening, its strange that some of you are saying yours are running fat with the same mods as me, after I fitted a k&N mine run poorly so I lifted the needles and put 144 main jets in and it now feels a lot better it even starts better
It was still fat after K&N and cans....so i just got the FCR´s instead of fiddling.
Tourqe-a-holic
- Killerwhale
AFAIK the stated power by Yamaha in workshop books are ~79 hp at the crank.....wich should mean that you´ve got a ~13% increase in power....rs1800 wrote:nice figures.
Anyway here are the charts, how does 79bhp at wheel compare to other standard trx's or should I start a new post?
thanks
But as everyone said....a dyno is used to get a % increase when tuning....
Tourqe-a-holic
- burty
That 79bhp figure will be at the crank not at the wheel.Killerwhale wrote:AFAIK the stated power by Yamaha in workshop books are ~79 hp at the crank.....wich should mean that you´ve got a ~13% increase in power....rs1800 wrote:nice figures.
thanks
				rs1800
- burty
