Phone Holders
Trx envy
Phone Holders
What are you guys using to mount your phones? Pics?
- Rod.s
Re: Phone Holders
- Snod Blatter
Re: Phone Holders
Not a phone but..
No good in the rain though, falls straight off!
Trx envy
Re: Phone Holders
Is it a suction cap? Yeah not sure id trust expensive devices on that.
Rod, haha, yeah not for social media so much as maps.
- Snod Blatter
Re: Phone Holders
It is the large RAM suction cup. I wasn't sure if it would hold on the curve of the screen but it does, at least in the dry.
I believe you can get RAM mounts for the mirror mount too, has anyone tried this? For me the device has to be up there, I was tempted to fit the suction cup to the tank but it's a nightmare to try and look at it when you're moving.
Trx envy
Re: Phone Holders
I'm wondering if anyone is using a winshield bolt or mirror bolt on the inside of the fairing to pick up a mounting point maybe?
My last bike had a tube brace inside the nosecone which was handy. I just used one of these silicone stretchy boys. Just chuck it in my pocket when i parked the bike. Was actually pretty good.
- Rod.s
Re: Phone Holders
I've a alloy tube section that slides into the recess of the left bar, secured with a slightly longer "Allen" bolt. It's sized to the standard bar size 7/8 (22mm) so fits all the commonly made bar attachments (Ram, Ball etc). Although it looks to be obtrusive and may get in the way, it doesn't and I've had everything from a clock to TomTom attached to it, even on full left lock it didn't foul the faring..
Trx envy
Re: Phone Holders
^ thats awesome. Did you machine that out of a bit of round stock?
- Rod.s
Re: Phone Holders
Yep I'll find it and take some measurements if that helps..Trx envy wrote:^ thats awesome. Did you machine that out of a bit of round stock?
- Rod.s
Trx envy
Re: Phone Holders
Very clever. Thanks for sharing.
I really need to invest in a lathe
- Tarwetijger
Re: Phone Holders
Thought the forks were really low but now I see it's the clipons that are raised.Rod.s wrote:I've a alloy tube section that slides into the recess of the left bar, secured with a slightly longer "Allen" bolt. It's sized to the standard bar size 7/8 (22mm) so fits all the commonly made bar attachments (Ram, Ball etc). Although it looks to be obtrusive and may get in the way, it doesn't and I've had everything from a clock to TomTom attached to it, even on full left lock it didn't foul the faring..
I have something else, will post a pic later.
- Rod.s
Re: Phone Holders
Yep a little bit raised but just for touringTarwetijger wrote:Thought the forks were really low but now I see it's the clipons that are raised.Rod.s wrote:I've a alloy tube section that slides into the recess of the left bar, secured with a slightly longer "Allen" bolt. It's sized to the standard bar size 7/8 (22mm) so fits all the commonly made bar attachments (Ram, Ball etc). Although it looks to be obtrusive and may get in the way, it doesn't and I've had everything from a clock to TomTom attached to it, even on full left lock it didn't foul the faring..
- Killerwhale
Re: Phone Holders
But would you not always be lathe??Trx envy wrote:Very clever. Thanks for sharing.
Trx envy
Re: Phone Holders
Im always late anyway
