If you didn't already know... as a user of this forum you’ll get a discount of up to 20%, and at least 10% at Opie Oils…
And as one of our rare but wonderful across-the-board offers, you can get an additional 15% off using voucher code OPIEEGG, and there’s no minimum spend either [
So, if you haven’t already registered, register on the Opie Oils web site (free), use our Easter Special discount voucher – OPIEEGG - and until midnight on Easter Monday you can get a discount of at least 25% off retail prices across our product range:
• 25% - 35% off all car and motorbike engine oils
• 25% - 35% off all gear oils and final drive oils
• At least 25% off motorbike oil and filter service packs
• 25% off all cleaning products (Muc-Off, Motul, Castrol and Silkolene)
• 25% off Denso Iridium spark plugs (high performance, long life plugs)
• 25% off all coolant, chain sprays and workshop products
• 25% off motorbike filters
Log in as a member to get your 10 - 20% discount, then use code OPIEEGG at the checkout to get your additional 15% off… up to 35% off RRP. If you run a car as well as your motorbike, the offer is good for all car products too, apart from our range of Brembo Max, Brembo Sport and Brembo GT Kits (you'll get your usual member's discount). Everything else is in, though!
If you've not already registered, register now here:
Happy Easter from us all at Opie Oils!
www.opieoils.co.uk
