Losing pressure
Red Rex
Losing pressure
Post by Red Rex » Mon Jun 07, 2010 7:57 am
Two weeks of not being used ... rear tyre pressure dropeed to 8psi
Pumped it up to 36psi.
Overnight dropped to 20psi
Gave it a good inspection for flints, nails, nicks & cuts - None found
Soap solution around the valve - No bubbles
Pumped it back to 36psi
Dropped to 33psi overnight.
... any suggestions as to cause or cure ????
Its got too much life in it to want to fork out over £100 for a new tyre [-o<
Re: Losing pressure
Post by trixynut » Mon Jun 07, 2010 10:17 am
Only causes are valve or puncture. if you're sure its not the valve or valve seat, then its a puncture that you've missed when you inspected. Unlikely to be the bead (tyre/wheel interface) leaking.
Get it out and take it to the nearest river/paddling pool/bath to check..
Re: Losing pressure
Post by Mincehead » Mon Jun 07, 2010 6:06 pm
Yep agreed, wheel oot an dip it!
(That`s the wheel nothing else.) :lol:
Red Rex
Re: Losing pressure
Post by Red Rex » Tue Jun 08, 2010 7:55 pm
Hah !! Guess wot :?:
Washing up liquid solution shows there is a very light leak between the tyre bead and the wheel rim on the drive side opposite the valve.
I've tried totally deflating the tyre and re-inflating it but it's still weeping.
Guess the only option is to get the tyre taken off, inspect and clean the offending areas of both tyre and rim and have it re-fitted (after rotating the tyre 180°) and re-balance.
Trixy & Mince ... just 'cos you were wrong this time doesn't mean I won't ask your advice again in the future :oops: :D
Re: Losing pressure
Post by Mincehead » Tue Jun 08, 2010 8:32 pm
Fairy liquid eh, name dropper!
I use the cheap 30 pence unbranded stuff, at least your hands will be soft. :wink:
Red Rex
Re: Losing pressure
Post by Red Rex » Wed Jun 09, 2010 7:42 am
Who mentioned anything about Fairies ?? :shock:
Re: Losing pressure
Post by Mincehead » Wed Jun 09, 2010 1:11 pm
Ahem, yes, gilded the lilly a little for the soft hands pun. :oops:
Had to be done. :wink:
