Any suggestions as to how far to drop yokes without causing too much excitement?
120/70 front tyre, hmmm.....
- Rural Rat
Just changed to 120/70 front tyre as appears to be the consensus here. Not real impressed. Steering is now very heavy and extremely slow, not confidence inspiring at all. Tyre is Metzeler M1 and rear is Michelin Pilot Road. Forks are still at original height.
- H1
Hi !
Can´t understand your problems. But eventually it depends that you´re using different tires in front and rear? Did you use the right pressure? Normal road i go with 2,5 bar in front and 2,8 rear.
I´m using Maxxis Supermax in front and rear or Michelin Pilot Power in front and rear... everything works fantastic and easy!!!
Hope u get it fine!
Ciao!
Heinz
Hope u get it fine!
Ciao!
Heinz
- burty
I've just fitted a 120/70 on the front of mine. I've not ridden it yet then.
WRT the difference in diameter. I know that the difference is not always the same as theory, but I make the theoretical difference in 'tyre height' to be 12 mm.
That is:
120 x 60/100 = 72
or 120 x 70/100 = 84
Actually that is a lot more than I expected - just in my mind.
I guess that makes 10mm a reasonable adjustment on the forks.
BTW, has anyone changed the rear for a 70 profile too?
That is:
120 x 60/100 = 72
- Max
- Janitor
Increments of 5mm is my usual practice before I fine tune. Saves time and yes, a couple mm make a difference.
First make sure your sag and spring rates are set. I never recommend running two different models, let alone brands of tire on a bike. They are designed to work together.
Mine with Pirelli Dragon Super Corsa Pros on the track and on the street (120/70, 180/? with a 5.5" wheel) flip flop through direction changes like the bike weighs half of its actual weight. I'll be going with the Diablo range later as I don't see any track time in the near future.
You need to set it up. I had to spend a couple sessions of track time to reset mine when they went to the "Pro" version. It was a taller yet rounder tire and I was dragging stuff while pushing the front. Ended up raising the rear. On the road, this won't be a problem, but the geometry issues still matter.
- Greg
Different brands front and rear might have a huuuuge effect...
As far as I'm aware, manufacturers match their profiles front and rear, so that the tyres at each end do the same thing at the same time - contact patch aspect, angles of incidence etc... Imagine a really peaky front (I've got some Pirellis that appear to be almost triangular in shape!) matched to a squat fat rear... If both tyres have the same relative profiles then they'll do the same thing at the same time, if the front is significantly different to the rear, like I've described above then it will behave completely differently with the front wanting to fall off the edge while the rear kinda rolls over its profile..
Just my five eggs...
G
G
120 / 70 is the way to go. The 60 profile was only put on there to satisfy the Japanese obsession for low profile tyres and also found it's way onto the early r6 - Yamaha soon changed its mind!
I would suggest that any problems are due to suspension set up, tyre mis matching or wrong PSI not the tyre.
Strange - 70 profile should give a greater contact patch when cranked over and give more confidenceDoyle171 wrote:I have a 120 / 70 on mine and the change of direction is quicker but i will be going back to a 60 as the front end feels vague in fast sweepers.
- burty
YZF750, FZR1000, R6 all have a 120/70 front and a 180/55 rearGreg wrote:Different brands front and rear might have a huuuuge effect...
G
R1 has 120/70 front and a 180/50 rear
dfh
Like Phuk says the 70 series will enhance stability and feel, and without changing the front ride height the 70 will slow down the steering not speed it up....... your problem lies elseware in the chassis.Doyle171 wrote:I have a 120 / 70 on mine and the change of direction is quicker but i will be going back to a 60 as the front end feels vague in fast sweepers.
DFH
- Wombat
- Forum Marsupial
