my trx project
my trx project
thought id stick up some pics of my project , will be using this more or less as is for now until my yzf project is finished then this will come off the road for a full strip and rebuild , starting with the forks , got some yzf750 forks ,cut the stem out my self and had it pressed in today so I thought id bolt it on , didn't no it would hit ( I take it I have to cut the stop off )
also my blue spots don't fit ( do I have to use spacers or can I cut into the forks to make them fit )
gona nick the rest of the parts I need from my yzf750 ie front wheel and mudguard until I get the money to replace them , will also be doing rear end yzf as well but that wont be for a while yet , might stick a r6 tail on (03) type as I have 1 sitting around , will prob go the streetfighter look not sure yet
I will stick more pics up as I do bits
- ricr378
Re: my trx project
That's nice and neat bet mine don't come out like that Cheers m8 for pics very helpful will have a go today if not raining
Re: my trx project
finished the front end today took for a quick ride round the block as it has no mot or tax , all was good ,
think I need a new front tyre
next on the list to do is end cans I have some carbon cans there a little beaten up so gona chop them need to take about 5 to 6 inches off , aint got a clue who there made by , also 1 of the link pipes is dented in a few places ( can these dents be pulled out ?) not to worried as these only cost me 40 quid
Re: my trx project
Mad73, be sure the blue spots are not touching the fork cut out anywhere as you will have feedback through the brake lever.
A one millimetre gap maybe....looks good tho,
Reminds me of my purple rim from way back...a rattle can of quick dry paint would be a short time fix.
The photo above with the blue spots in the silver adjustable forks would be about right for distancing.
Try and find a 14mm master (if you don't already have one) ..better feel from the blues.
Re: my trx project
I have gap round them so all should be good . Just gona leave the wheel not to worried how it looks as the whole thing will get striped next year for rebuild powder coat frame pos engine rebuild with big bore pistons will be on the look out for carbs want it to look brand new when finished
Mick
Mick
Re: my trx project
Little update was gona do the exhaust cans next but just bagged a yzf swingarm for 40 quid free post as well so swinger is next on the list . From wot I've read it's just a straight bolt in job and flip the rear trx sprocket on the yzf wheel . Don't think my trx sprocket is dished sure it's flat so where would I get a dished sprocket from
Thanks
Thanks
Re: my trx project
A dished sprocket is a standard Yamaha one, as opposed to aftermarket ones like renthal etc.
But the bigger 180 yzf rear has a larger circumference to the 160 so you may want to mess around with the number of teeth.
Plenty of info on here if you search.
Re: my trx project
little update got the swinger fitted over the weekend just need to sort the rear brake out as it was binding and sort the chain as well , gona drop 1 tooth on the front so have to buy 1 of them ,
yzf swinger in
exhaust is quit close didn't think it would be that close
all done more or less sorry for the bad pics had dust on the lens
yzf swinger in
- Tarwetijger
Re: my trx project
The exhaust and swingarm are not going to work like this. With vibrations and the swingarm moving up and down, these will touch and scratch for sure! Can't you move/twist the exhaust a little outwards?
Re: my trx project
Changing end cans soon so will have a little play I'm not riding at the minute as no tax or mot
- Con Rod
Re: my trx project
mad73 wrote:Little update was gona do the exhaust cans next but just bagged a yzf swingarm for 40 quid free post as well so swinger is next on the list . From wot I've read it's just a straight bolt in job and flip the rear trx sprocket on the yzf wheel . Don't think my trx sprocket is dished sure it's flat so where would I get a dished sprocket from
Thanks
It is not a straight swap, I mentioned this somewhere before, but you need to move both spacers at the swing are pivot to the left side
This moves the swing arm 5mm right
Then you need to mill 5mm off of the rear calliper carrier and add a 5mm spacer to the left side.
This will move the wheel a further 5mm right
If you don't do this you front and rear wheel will not be correctly aligned.
see here:
viewtopic.php?f=34&t=7466
Re: my trx project
Not saying your wrong or any thing like that as I alway welcome advice but I was under the impression that I was a straight swap over and flip the rear trx sprocket on the yzf wheel that's wot I've read on this forum but if that is wot I have to do then thank you for letting me no
Mick
Mick
- Con Rod
Re: my trx project
mad73 wrote:Not saying your wrong or any thing like that as I alway welcome advice but I was under the impression that I was a straight swap over and flip the rear trx sprocket on the yzf wheel that's wot I've read on this forum but if that is wot I have to do then thank you for letting me no
Mick
yep I originally fitted it straight in based on the post on the forum and then found the wheel alignment was out
I suggest you measure the alignment.
You may find the front wheel and rear wheel are 10mm out of aligment
