TRX front wheel in R1 forks
Posted: Sun May 26, 2013 3:24 pm
The R1 front on a TRX is a great march and pretty easy to get hold of, but there's just one problem; As many would be aware, the R1 speedo doesn't run from the front wheel (rather it has sensor pickup on the output shaft I think? doesn't matter..) so to keep the original TRX speedo whizzing about, you'll want to use the TRX front wheel, but then you find that the R1 axle is too fat and won't go through the TRX hub which can't be machined to take a larger bearing. Bummer.
So, TRX axle diameter... too skinny for R1 axle bores. End of story? Not necessarily. What I needed was an axle that was fat on the ends but skinny in the middle, that could still be poked through the wheel hub. Solution; a composite axle. It sounds radical, and was a little bit of a muck-around for sure, but in my opinion well worth the effort.
To explain the attached design diagrams below; red bits are original R1 (2000) - green bits are TRX - blue bits are custom fabricated.
Basic run-down of the task was as follows;
1. Threaded end of R1 axle is cut off at 54.5mm long and threaded internally to accept M12 HT bolt* at the outer end. The end facing inward may need to be bored to 17mm to accept the TRX axle. This part will effectively sleeve the R1 left fork axle-bore to accept the smaller diameter TRX axle.
2. The TRX axle is cut down to an inside length of 218.5 mm, and also threaded to M12 and fitted with a M12 x 50mm HT bolt (with head cut off), permanently fixed in place with thread-locking compound (after test fitting of course). Even though the bolt is HT, wheel forces are transferred directly from axle to fork ...any load on the bolt is negligible.
3. A steel or aluminium bush (ED 28mm, ID 17mm, Length 28.5 mm) needs to be turned up and fitted to the Right-hand end of the TRX axle. IMPORTANT!;[/b] the axle must be completely unable to rotate inside this bush, otherwise the axle could unwind itself during riding, despite the clamp bolts in the fork axle-bore being done up tight.
4. Because the R1 doesn't have a front-wheel mounted speedo drive, it doesn't allow for placement of such between the wheel hub and the left fork on the axle. A few mm of material (forgot how many exactly) will need to be machined off the inner face of the left fork to allow room for the TRX speedo drive and keep the wheel centred in the forks.
5. To prevent the free rotation of the speedo drive, I made a small L-shaped locator lug from 3mm aluminium and fitted it to the inner face of the left fork by drilling and tapping a shallow hole and fixing with a small thread-locked bolt. *M12 bolt; diagram originally had 13mm 14mm threads specified, but axles were found to have sufficient thickness to allow 12mm thread which made fabrication much simpler.
NOTE: As stated on the diagram, it should be noted that this drawing represents a modification that is yet to receive engineers approval. Laws regarding road use may apply to it's application in various jurisdictions. No warranty expressed or implied.
