spondontrx
by spondontrx » Thu Jan 31, 2013 10:18 pm
zednine
by zednine » Thu Jan 31, 2013 10:22 pm
Very tidy ..... You are using the Trx head I assume ?
I wish I could keep my workshop that clean .......... In fact I wish I kept my living room that clean
Skybone
by Skybone » Thu Jan 31, 2013 10:37 pm
Can't wait to see the finished article!
by dixonj » Thu Jan 31, 2013 10:45 pm
Nice project keep us informed on your progress.
spondontrx
by spondontrx » Thu Jan 31, 2013 11:03 pm
zednine wrote:Very tidy ..... You are using the Trx head I assume ?
Thank you
and yes the TRX head is used
xxr55
by xxr55 » Thu Jan 31, 2013 11:54 pm
Me likey, likey. Two thumbs up.
xxr55
by xxr55 » Thu Jan 31, 2013 11:58 pm
Oh yeah, where do I get one of those Yamaha tank badges from?
rbaron25
by rbaron25 » Fri Feb 01, 2013 11:28 am
Not taking the mick.... Okay I am....
I can just picture Wallace or Gromit riding it in the primer colour....
Bananaman..
Very interesting love to see it finished
I didn't see you...
Cause you didn't bloody look!
spondontrx
by spondontrx » Fri Feb 01, 2013 1:08 pm
xxr55 wrote:Oh yeah, where do I get one of those Yamaha tank badges from?
I've made that to fit the tank better, so you can't order them (maybe send me a lot of money and I will see what I can do
by alextrx850 » Sat Feb 02, 2013 1:19 am
spondontrx wrote:zednine wrote:Very tidy ..... You are using the Trx head I assume ?
Thank you
A lot of advantages in the TDM 900..ive heard so much with the conversion, however a dark area would be the fitting of the 850 head to the 900 barrels..what thoughts there and i assume the TRX head still aligns to the frame same as the rex motor does or is that another mod..?
Would the main advantage on using the TRX head be to use the FCR 41s, ??
I note you have cut off the [head-off] engine support triangle bracket...
devlin
by devlin » Sat Feb 02, 2013 11:41 am
That is a sweet looking bike. Really really like that seat module. Very smooth. Only two things i would look at would maybe some late model forks and ergo late model brakes and a swingarm with some smoother lines. Think 675 or the Aprilia mod we have seen. or even the R6 swinger would look cool. Just to balance out the lines from the rear. I'm just thinking out loud here. As it is now it looks awesome and has given me another couple of ideas for my bike.
spondontrx
by spondontrx » Sat Feb 02, 2013 10:29 pm
alextrx850 wrote: however a dark area would be the fitting of the 850 head to the 900 barrels..what thoughts there and i assume the TRX head still aligns to the frame same as the rex motor does or is that another mod..?
The main reason for using a TRX head is because the front mounting points are at the front of the 900 cilinder , the 850 head fits no with problem so there is no need to change the frame ,
And I happen to prefer carbs (especiali flat slide types) witch is another reason for not using the 900 head
The triangle brackets on both side can't be used because the 900 engine doesn't use them , but I'm not to worried about that .
The biggest problem is the alignment of the chain sprockets ,for this I machined 4 mm of the collar witch is on the output shaft (behind the sprocket) this together with the YZF wheel and swingarm solves this problem (I also am gonna use a 520 chain witch gives me a bit more space)
sydallen
by sydallen » Wed Feb 06, 2013 5:50 am
What is the extra aluminum bracing on the swing arm? My '98 does not have this.
Bullet
by Bullet » Wed Feb 06, 2013 9:09 am
Being an oldie I'm putting on my hard hat and poking my head above the parapit waiting for the brick bats, but wouldn't it look cool fitted with (in a whisper) twin shocks?
I'm addicted to brake fluid, but I can stop anytime.
by alextrx850 » Wed Feb 06, 2013 10:28 am
Bullet wrote:Being an oldie I'm putting on my hard hat and poking my head above the parapit waiting for the brick bats, but wouldn't it look cool fitted with (in a whisper) twin shocks?
ill stand behind you there Bullet, with another hard hat on and in high heels and,..[in a whisper] suggest wire wheels..?
