yzf 750 forks
Posted: Thu Jan 31, 2013 4:40 pm
Hi could someone who has yzf forks fitted to there trx do me a favour and measure the distance between the forks in the top yoke also the distance between the discs.
Cheers j
Cheers j
Hi Kayla it's not the pitch distance I need but the distance between the forks it should be either 160mm or 170mm. I have just bought some r1 4xv yokes and the are 10mm narrower the the yokes fitted 160mm.Kayla wrote:The pitch is 210mm and I think the distance between the discs is 6mm more than the standard TRX (ie the YZF hub is 6mm wider)
Hi Dixon you can use the pitch measurement ..... just measure the inside of one fork leg hole to the outside of the other ....dixonj wrote:Hi Kayla it's not the pitch distance I need but the distance between the forks it should be either 160mm or 170mm. I have just bought some r1 4xv yokes and the are 10mm narrower the the yokes fitted 160mm.Kayla wrote:The pitch is 210mm and I think the distance between the discs is 6mm more than the standard TRX (ie the YZF hub is 6mm wider)
Thanks Phil it helps loads my fork bottom must be slightly different to the yzf.misterdimwiddy wrote:My YZF front end measures up to be 160mm between the fork legs at the top yoke and 142mm between outer edges of discs (Galfer). 130mm between disc inner faces. Only measured with a tape measure though, not a vernier.
Hope this helps.
Phil
Interesting topic, so what type of fork bottom are you using ?dixonjdixonj wrote:Thanks Phil it helps loads my fork bottom must be slightly different to the yzf.misterdimwiddy wrote:My YZF front end measures up to be 160mm between the fork legs at the top yoke and 142mm between outer edges of discs (Galfer). 130mm between disc inner faces. Only measured with a tape measure though, not a vernier.
Hope this helps.
Phil
How is your FZR 1000 front fork fit up going Dixon ?dixonj wrote:Fork used are from a late FZR1000 RU 1995, which use the same wheel,disc and calliper set up as the YZF 750. The only difference I have found so far is that the FZR uses wider yokes 170mm instead of 160mm used in the YZF/R1. When I build up the forks using the R1 yokes hopefully I will be able to find out where the differences are.
