HID kit
srussell
HID kit
Hi there, I am thinking about installing a HID kit. One, so I am more visable to other drivers and two, amount of light emitted from headlight is poor. Has anyone out there installed one of these and is it worthwhile? Cheers Steve.
- M.V.
Re: HID kit
G'day Steve,
Yes, it's a good addition, it's better than stock, but still not perfect. A projector retrofit would be the best idea, check these guys out:
www.theretrofitsource.com
I'm currently working on a dual HID projector setup, do a search on here, there's a bit of info about.
Re: HID kit
Same as MV..you wont have the spotlight type of high beam as the bulb has, but the H.I.D set up seems to splay the lights intensity over a wider area..and the bluish intense light brings up anything reflective in front for quite a way...and the cage drivers really can see the diference so it seems.srussell wrote:Hi there, I am thinking about installing a HID kit. One, so I am more visable to other drivers and two, amount of light emitted from headlight is poor. Has anyone out there installed one of these and is it worthwhile? Cheers Steve.
The fitting isnt too bad as if youve bought the one for the trx on e-bay as i did, the kit is made for the machine and the instructions are followable.
Be carefull not to handle the bulb and make sure the bulb fits into the holder freely...and then the whole lot into the rear of the headlamp.
Ive H.I.Ds in my other vehicles and havent had any issues
srussell
Re: HID kit
thanks for your help fella"s
srussell
Re: HID kit
Hey ALEX, where did you mount the ballast?
Re: HID kit
Hi srussel..mounted the ballast on the lower platform of the inner fairing, where the little air vent is under the headlight...it also keeps the water tight ballast cooler and used a self adhesive velcro ....it sits flat to the horizontal and is out of the way...srussell wrote:Hey ALEX, where did you mount the ballast?
srussell
Re: HID kit
thanks for the tip. regards steve.
Dan 850
Re: HID kit
Any link, I can't find a kit for the trx. It's maybe the eBay on my phone playing up.srussell wrote: The fitting isnt too bad as if youve bought the one for the trx on e-bay as i did, the kit is made for the machine and the instructions are followable.
Cheers dan
Double the fun if your riding twins! Shame her sister doesn't think so.
Re: HID kit
Hi Dan, im not sure to the e-ebay link, but its on our Australia e-bay...try to search the e-bay international...
i think the purchase country was England.
Dan 850
Re: HID kit
No worries, I found one now, there's one listed under trx 850 hid. I put in trx 850 hid kit, and didn't show anything.alextrx850 wrote:Hi Dan, im not sure to the e-ebay link, but its on our Australia e-bay...try to search the e-bay international...
60 odd quid, mine was only £43 for my car and thats 2 of everything and in h4, Reckon I can make one up, out of spares I have thinking about it.
