M.V.
by M.V. » Wed Jul 04, 2012 7:13 am
You need:
An R6 front sprocket in 520. The R6 stock is 525 (Same as the TRX) but 520 conversion is common for these. AFAIK, only Driven make a 17T version, 16 is stock.
An NX-650 Rear sprocket, in any amount of teeth you like, I'm going with 43. 520 is standard. The TDM900 rear sprocket will also fit the TRX, although AFAIK there is only a 530 conversion available for that. Obviously, a stock R6 front & TDM rear in 530 would also give you a 530 option
A 520 chain. I'm going with a DID VX2
Total cost: $196.85.
by Mincehead » Wed Jul 04, 2012 8:39 am
Good find and information M.V
M.V.
by M.V. » Wed Jul 04, 2012 11:34 am
Hopefully so Mince, just going what the parts guys have told me plus a lot of research on my part at this stage, but I've fronted up the cash, so should be confirmed or busted shortly
by alextrx850 » Thu Jul 05, 2012 5:12 am
M.V. wrote:Hopefully so Mince, just going what the parts guys have told me plus a lot of research on my part at this stage, but I've fronted up the cash, so should be confirmed or busted shortly
Nothing like the thrill of just diving in..M.V...sounds right though...hope you are at the DEEP end of the pool.
Italian Red
by Italian Red » Thu Jul 05, 2012 11:26 am
hi there
i've found a kawasaki ZX-6R 03-09 Afam front sprocket for my 520 conversion and fits perfectly.
M.V.
by M.V. » Fri Jul 06, 2012 6:20 am
Italian Red wrote:hi there
That's interesting, what rear sprocket did you use?
The JT Sprockets website has the ZX-6R sprocket looking the same as the R6 except with threaded holes for securing, is this correct?
M.V.
by M.V. » Tue Jul 10, 2012 12:36 am
Rear sprocket has arrived, mounting holes line up, but there is a recess where the sprocket nuts go, not sure if the TRX ones will sit in the cutout yet or not, I also think the mounting hole dia is slightly smaller, haven't measured yet, just eyeballing...
Will measure & update.
cal
by cal » Tue Jul 10, 2012 8:07 am
Cal
M.V.
by M.V. » Wed Jul 11, 2012 5:34 am
8.8mm mounting holes on the Honda VS 10.3mm on the TRX... Not a straight swap then.
TDM900 sprocket would be a better choice if it's available in 520...
M.V.
by M.V. » Tue Jul 17, 2012 12:58 am
Although apparently, if you rotate the sprocket a little, there are 10.5mm mounting holes
Just waiting on the front sprocket now...
Italian Red
by Italian Red » Tue Jul 17, 2012 8:11 am
M.V. wrote:Italian Red wrote:hi there
well, the rear sprocket is an ergal Afam sprocket but i use a R1 2000-2002 rear wheel. I've found some front sprocket in my warehouse (i work in a online shop) and i've tried several solutions. The R6 don't fit, the ZX one is simply perfect, i've installed it on the shaft without modifications. Tomorrow or the day after tomorrow i'll shoot some pics to show the stuff
M.V.
by M.V. » Tue Jul 17, 2012 12:46 pm
Italian Red wrote:well, the rear sprocket is an ergal Afam sprocket but i use a R1 2000-2002 rear wheel. I've found some front sprocket in my warehouse (i work in a online shop) and i've tried several solutions. The R6 don't fit, the ZX one is simply perfect, i've installed it on the shaft without modifications. Tomorrow or the day after tomorrow i'll shoot some pics to show the stuff
Bummer, I've ordered the R6 one. Might not be too late to change it...
Pics would be great, I would appreciate that.
Yami
by Yami » Tue Jul 17, 2012 2:03 pm
M.V. wrote:An NX-650 Rear sprocket, in any amount of teeth you like, I'm going with 43. 520 is standard.
Thanks for the tip.
There is a 520 front sprocket for Versys from JT that can be used with a small spacer, JTF565.
You then have the choice of 12-18 teeth.
M.V.
by M.V. » Wed Jul 18, 2012 12:27 am
& thank you for the tip on the front sprocket
Italian Red
by Italian Red » Wed Jul 18, 2012 12:27 pm
M.V. wrote:Italian Red wrote:well, the rear sprocket is an ergal Afam sprocket but i use a R1 2000-2002 rear wheel. I've found some front sprocket in my warehouse (i work in a online shop) and i've tried several solutions. The R6 don't fit, the ZX one is simply perfect, i've installed it on the shaft without modifications. Tomorrow or the day after tomorrow i'll shoot some pics to show the stuff
errata corrige:
sorry is not a kawa sprocket but a Suzuki GSXR 1000 k7-k8 one
Afam code 28402-17
Pics will be posted asap
