R1 rear shock
Posted: Sun Jul 01, 2012 2:06 am
by gereen50
Hi all,
My stock rear shock is shot and I have the opportunity of a 2011R1 shock that has nothing done. I'm about 206 lbs so the R1 should suit my weight. What mods do I have to do to make this fit or is there a better alternative ..
Thanks in advance again guys,
Gereen.
Re: R1 rear shock
Posted: Sun Jul 01, 2012 9:12 am
by fung
check the forum for a thread on shocks.
One of the Kwaka zx series shocks is the right length and fittings.
Or use a late model R6 shock with a kayla adapter.
Fung
Re: R1 rear shock
Posted: Sun Jul 01, 2012 10:08 am
86kg...thats is the what the R6 spring is rated
Re: R1 rear shock
Posted: Sun Jul 01, 2012 4:06 pm
by gereen50
OK Ive gone through the serch option and found squat that will hepl me... from my understading Yamaha dont make a specific shock for the R1 and the R6 so its logical that they are the same shock with the R1 having a stiffer spring . Im 206 lbs or about 95kgs .
So again Im asking for some help here.... will the R1 shock fit the TRX with the R6 adapter or would the zx10 shock be a better option ??
Re: R1 rear shock
Posted: Mon Jul 02, 2012 9:52 am
is the R1 shock the same length as the R6? maybe contact Kayla who produces the adaptors as she may have an idea on the R6 specs of the shock to compare against the R1.
Re: R1 rear shock
Posted: Tue Jul 03, 2012 12:23 am
by Gix
All the R1 shocks I have seen have had an eyelet at the botton rather than a fork
Re: R1 rear shock
Posted: Tue Jul 03, 2012 12:40 am
by gereen50
Gix wrote:All the R1 shocks I have seen have had an eyelet at the botton rather than a fork
Nuf sead....I sent a pm to Kayla and it looks like Im going for the R6.....
Thanks to everyone for your input....cheers guys...
Re: R1 rear shock
Posted: Tue Jul 03, 2012 8:40 am
by rct
have you considered just changeing the spring?
RCT
Re: R1 rear shock
Posted: Tue Jul 03, 2012 2:13 pm
by gereen50
rct wrote:have you considered just changeing the spring?
RCT
Not an option as the original is weepind....
