Hi,
I was wondering if it's possible to fit a YZF 750 rear wheel (5,5) on the TRX in order to use 180 tyres
Second question does a front wheel of a Fazer 600 fits on the TRX? It is to use as a spare wheel for track .
Wheels
- tz250w
Yes, I am using a YZF750 5.50 rear and 180 series Pirellis on my bike. I posted the data on the 'old' TRX forum and it is now lost...
The YZF and TRX have different spindle diameters so I used bearings that had the outside diameter of the YZF and inside diameter of the TRX both of the same width. I also had to shorten the collar inside the sprocket hub and turned the stock sprocket around to match up the chain line.
I'll try to get the bearing numbers and width of the collars on my bike the next time I pull the rear wheel off.
Don't know about the Fazer wheel, sorry.
BTW, Olivier. Please be patient about the rearsets. I should have final information in the next few days...
TaZ (Max)
