acewell 3963 digital
Posted: Mon Feb 06, 2012 8:56 am
Thanks to Con Rod and a rear seat swap, ive come accross the digital unit ive been looking for.
Ive always been old school with an analogue tacho but the digital speed readout is a sweet upgrade i think....
This one was able to be clipped OUT of the bigger case that also housed the idiot lights which made it smaller still...and it has a large readout....nice.
It also is fitted with the base speedo drive [at the axle] cable drive reader which my YZF front still employs..nicer
All ive done is to separate the speedo lense from the rest of the TRX unit..removed the speedo mechanicals....OH if you do remove the mechanicals, you turn the TRIP meter spindle CLOCKWISE as its got a left hand thread to wind it out allowing the mech to be lifted out....
The clocks are ones that i bought from the UK three years ago and have MPH showing , but as i only have glued an alloy round blank onto the vacated speedo apparture which the acewell bolts into, it could [except the separated lenses] be refitted back in minutes.....see the image.
The last image is of my steel locker inner door that i felt pen write on masking tape all the purchases , serviceing , and fit ups...how you you do it..?....
I guess that if ever the Trx is sold ..the door would go with it.heh heh
