Tuono Swingarm
kenmore
Tuono Swingarm
Post by kenmore » Fri Oct 14, 2011 12:36 pm
I have a mates Tuono in the garage. I changed the fork oil and saels and am giving it a good going over.
I love the look of the swingarm and wondered if anyone has fitted one to a TRX?
function=form
kenmore
Re: Tuono Swingarm
Post by kenmore » Fri Oct 14, 2011 12:37 pm
Correction- seals!!!
function=form
Re: Tuono Swingarm
Post by Mincehead » Fri Oct 14, 2011 12:49 pm
Yep, there has been a rather nice fightered Tuono front and rear ended TRX done. I think it was in Sweden, maybe Killerwhale will be along sometime to confirm that.
Very nicely done, silver bike if I remember corrctly, the Tuono Ohlin forks were gripped in some very nice billet yokes too. :wink: I`m not sure of the difference in weight between the TRX swingarm and a Tuono or Mille arm though.
HolerTogni
Re: Tuono Swingarm
Post by HolerTogni » Fri Oct 14, 2011 2:29 pm
Hi kenmore!
A member of the German TRX forum has fitted a RSV Mille Factory (=Oehlins) front end and swingarm to his TRX which is for sale at the moment.
(I think the swingarm of the Mille is identical to that of the Tuono)
Cannot say a thing about the drivability of this conversion.
Linked greetings from Munich!
Re: Tuono Swingarm
Post by Killerwhale » Fri Oct 14, 2011 3:07 pm
Mincehead wrote:Yep, there has been a rather nice fightered Tuono front and rear ended TRX done. I think it was in Sweden, maybe Killerwhale will be along sometime to confirm that.
I think you mean "Peder" and his RSV factory banana swinger :)
Re: Tuono Swingarm
Post by Mincehead » Fri Oct 14, 2011 3:23 pm
Ahhh yes RSV / Mille / Tuono, they`re pretty similar. That`ll be the one, seemed to remember it as being in Sweden, cheers Kw. :wink:
kenmore
Re: Tuono Swingarm
Post by kenmore » Fri Oct 14, 2011 9:39 pm
Thanks guys, another crazy idea on my part!!!
function=form
Re: Tuono Swingarm
Post by alextrx850 » Sat Oct 15, 2011 12:26 am
What was with his clutch cover..?,
HolerTogni
Re: Tuono Swingarm
Post by HolerTogni » Sat Oct 15, 2011 11:14 am
Hi alextrx850!
alextrx850 wrote:What was with his clutch cover..?,
alextrx850 wrote:is this inside the plastic cover..??
Seemingly. I never removed the clutch cover (I coverd the clutch cover with a carbon cover instead).
Maybe he was ashamed of the "YAMAHA" reading on the clutch cover after fitting the Aprilia parts (there was a kind of bigger discussion in the German forum because he modified it without riding the original TRX one single meter and made snidely remarks on the original parts [as said without having ridden it], when I remember correctly)?
I don't know really - maybe he liked the "pure" aluminium look better than withe the plastic cover on it?
Guessing greetings from Munich!
jocke
Re: Tuono Swingarm
Post by jocke » Sat Nov 26, 2011 1:59 pm
I've done a similar job on my TRX. The newer rsv swing arm are a bit wider, so I had to mill off 8mm off the alloy subframe.
jocke
Re: Tuono Swingarm
Post by jocke » Sat Nov 26, 2011 2:02 pm
pic of it
schmiffee
Re: Tuono Swingarm
Post by schmiffee » Sat Nov 26, 2011 2:05 pm
That does look freakin hot!! :P
Re: Tuono Swingarm
Post by Killerwhale » Sat Nov 26, 2011 4:19 pm
jocke wrote:pic of it
Eheem, and when will the turbo kit be on there?? :wink:
(Vad är det för bakram på den och hur gjorde du?)
jocke
Re: Tuono Swingarm
Post by jocke » Sat Nov 26, 2011 7:39 pm
Well... since it apperes to be an never ending project, I don't know :) First goal is to get the bloody thing going again after all theese years.
Egen bakram som jag svetsat ihop själv. Tog bara sisådär 100h med med allt testande å så...
