Big bore headers available soon
Re: Big bore headers available soon
Post by Killerwhale » Fri Apr 20, 2012 6:21 am
sanddune51 wrote:A mismatch between the exhaust port and the header tube is no bad thing at all. As long as the header has a larger bore than the port. It's better if the lower part of the port is a few mm higher than the exhaust header. It can be beneficial in hindering flow reversion. The short side of the port flows less gas and with longer duration cams the increased valve overlap can lead to flow trying to return back in to the cylinder. The long radius of the port and pipe does not suffer from this flow reversion and should be matched to provide a smooth transition.
On the (short or tight) radius of the exhaust port the flow tries to eddy and fold back under itself,a little like waves on the beach curling under themselves as they break. During the period when both inlet and exhaust valves are open the depression in the cylinder on the induction stroke tries to pull in spent exhaust gases.This is when flow can stall and then reverse. The inlet charge can end up with a degree of exhaust contamination. A mismatched step at the port to header face can serve to prevent this happening. A correctly designed mismatch can be power for free. :lol:
Mark
Yeah but it doesn´t as it´s 38mm.
Kayla
Post by Kayla » Fri Apr 20, 2012 6:28 am
Killerwhale wrote:
Marty Moose wrote:Looking forward to seeing the pics
Would have liked spring lugs for the exhaust can as well.
You didn't say you needed them!
Would it be an idea to have them put on every system from now on, just in case?
Post by Killerwhale » Fri Apr 20, 2012 6:47 am
Nah, should be an option me thinks. When ordered the MTC can they had both options and as the akra has lugs i opted for that.
No biggie to ask someone to tack on some, the important this is that it´s not puffing out where it shouldn´t 8)
Post by Killerwhale » Sat Apr 21, 2012 2:40 pm
Was out hooning around for 45 min, to hard to separate this one from Akra. But i think i´ve got the effect i wanted. Power went down lower but the dyno will tell. One nice thing though, i have "winder´s" breather on now and bike for sure revs to red faster.
Will fix one more breather...
Another input when i have cut out a bit on the downpipes so gasflow won´t hit the pipe.
Post by fung » Sun Apr 22, 2012 12:35 am
=D> =D>
more pics of your install please :D (breather, new pipes etc ).
:rr:
Post by Mincehead » Sun Apr 22, 2012 12:46 am
All you need is one of these, M14 x 1.5 to AN8 coupling that will screw into the hole the top plug in the alternator casing fits in:
http://www.ebay.co.uk/itm/8-AN8-08-M14x ... 230df5d527
Once you have an AN8 tapered coupling end you can connect hoses, right angled adaptors etc:
http://www.ebay.co.uk/sch/i.html?_nkw=A ... m270.l1313
You could run a hose up to the larger diameter hose from the cam cover and join into it with a tee piece or simply utilise a push in filter. :wink:
Post by fung » Sun Apr 22, 2012 1:48 am
thanx mince.
i do like the 'low' profile version tho.
i'm keen to see the TRX900 nexgen install ;)
:rr:
Post by Mincehead » Sun Apr 22, 2012 1:54 am
Yep M14 x 1.5 hollow banjo bolt and banjo to pipe ferrule works too of course:
http://www.ebay.co.uk/itm/14MM-FUEL-OIL ... 33581313dc
Mind, It `ll carry less air being a tad more restrictive due to the design of a banjo. :wink:
Post by fung » Sun Apr 22, 2012 8:01 am
hey mince :idea:
I found a 10mm hose kit on ebay.
http://www.ebay.com.au/itm/14MM-BANJO-1 ... 3f08a0de25
is that better ;)
:rr:
Post by Killerwhale » Sun Apr 22, 2012 8:41 am
Mincehead wrote:Yep M14 x 1.5 hollow banjo bolt and banjo to pipe ferrule works too of course:
Winder of cource had it drilled out some :)
..as we are getting off topic i´ll put pics in "my" thread...
craybait
Post by craybait » Thu May 03, 2012 12:08 am
Another 2-1 set with 60mm opening ordered for OZ courtesy of Kayla's site,I have a hex acropovic carbon can on a 2-1 locally made system which looks 'Daggy' were the pipe supplied for the gsr1000 was welded in.So should look smick and go faster soon,ordered lugs at the can end
Post by Killerwhale » Thu May 03, 2012 6:19 am
craybait wrote:Another 2-1 set with 60mm opening ordered for OZ courtesy of Kayla's site,I have a hex acropovic carbon can on a 2-1 locally made system which looks 'Daggy' were the pipe supplied for the gsr1000 was welded in.So should look smick and go faster soon,ordered lugs at the can end
Heel heatshield under construction by Kayla as i melted a chunk off my raceboot (pipe really close to peg, at least for us using tip toe style)
Post by fung » Thu May 03, 2012 9:06 am
sounds interesting that heel guard, as my 2-1 is also close as I ride with the ball of my foot on the peg too.
i also have rearset plates by Kayla which are 25mm up and 25mm back.
:rr:
Luckyou34
Post by Luckyou34 » Fri Oct 12, 2012 8:36 am
hello, I just mount the exhaust line 2-1. What model silencer can be mounted on? philippe
drix
Post by drix » Fri Oct 12, 2012 9:36 am
Luckyou34 wrote:hello, I just mount the exhaust line 2-1. What model silencer can be mounted on? philippe
Anything that has a 50mm diameter collar ;)
