TRX digital speedo
TRX digital speedo
I am looking to purchase a digital speedo and replace the analogue one..will be after a type that displays the speed reading the most ..RPM and coolant temp will be retained as will the idiot lights below..so basicly a compact device that replaces the bigger round one ,and are these back lit for night time?..i see a lot on e-bay..any good brands around 150AUD ?
- Kevtrx849
- Moderator
Re: TRX digital speedo
Koso make some nice units but a little bit pricey. Maybe wreckers might have some damaged clocks that you can rework.
( HENRY FORD )
( HENRY FORD )
The man behind this company (second link) is a member here too, see this thread:
viewtopic.php?f=44&t=6964&p=69835#p69835
http://www.digital-speedos.co.uk/
Plenty to wet your appetite there.
drmac
Quite a few of us have fitted new clocks due to losing speedo drive when we changed the trx front end . I have the Koso Xr/Sr fitted to my trx, It was very easy to fit and seems to work all ok after 2 years .i think a few people have fitted the vapour dash and had no problems.
NWS870R
Koso instruments feckin RULE!! Love my RX-2 unit on the rex - just about to fit more Koso kit to my TDR250 project. Certainly wouldn't call them expensive considering the build quality & broad range of functions.
- thch
+1 on that.
Have the Koso RX2-N and it works just great (along with the Garmin gps) - only thing missing is the fuel gauge.
Has anyone fitted a fuel gauge on the original tank?
zednine
i went for the vapor dash .......... works well
robin47
got a Acewell on mine £85 off e-bay
