single sided swing arm
- Kevtrx849
- Moderator
Re: single sided swing arm
I quite like this look and it does give the opportunity for fitting underseat exhausts.
( HENRY FORD )
( HENRY FORD )
- Kayla
... adding weight to the bike and length to the exhaust system, lowering power. Still, if it looks good...Kevtrx849 wrote:I quite like this look and it does give the opportunity for fitting underseat exhausts...
So you can gain a lot on an R1 or 1198 with a short system then?Kayla wrote:... adding weight to the bike and length to the exhaust system, lowering power. Still, if it looks good...Kevtrx849 wrote:I quite like this look and it does give the opportunity for fitting underseat exhausts...
- Kayla
Dunno, but those bikes are designed to use underseat exhausts, the TRX isn't.Killerwhale wrote:So you can gain a lot on an R1 or 1198 with a short system then?Kayla wrote:... adding weight to the bike and length to the exhaust system, lowering power. Still, if it looks good...Kevtrx849 wrote:I quite like this look and it does give the opportunity for fitting underseat exhausts...
if a ducati trellis frame is successful with a SSSA.. wouldnt a similar trellis frame.[trx]..and a ducati SSSA be a happening thing...> :roll:gotta say,fitting a SSSA from say the honda vfr 800 [seems to be the type most used in the past]--would be quite easy...Annyyyway..maybe i should buy a puppy instead. , and then id buy another one...and then put them side by side...and THEN put a bottle of beer between them...mmmmmm--i like puppys...
most SSSA images have the right side shown...i am not sure this left side photo would keep me happy long term..a bit ugly
Funny how things progress.
Just found this post from 2011..
Shows how thoughts can progress.
Out and about this morning..
Waiting for others at maccas.
