Gilles Chain Adjusters
Wombat
Forum Marsupial
Post by Wombat » Mon Oct 30, 2006 10:36 am
Has anyone seen these? Pure Bling! Of course they don't list any for the TRX. But I was thinking, would ones for say an early R6 fit? Are the dimensions of the axle cutout in the swingarm the same? From memory the dimensions are 45mm high, 88mm length and 24 - 25mm across the flat faces of the axle spindle end. Anyone know anyone that has an early R6 and could measure it?
burty
Re: Gilles Chain Adjusters
Post by burty » Mon Oct 30, 2006 5:23 pm
Wombat wrote:From memory the dimensions are 45mm high, 88mm length and 24 - 25mm across the flat faces of the axle spindle end.
I can't help, but I am curious as to how you happen to know this kind've information.
Wombat
Forum Marsupial
Post by Wombat » Tue Oct 31, 2006 5:30 am
Vernier calipers, Burty, of course :wink:
burty
Post by burty » Tue Oct 31, 2006 11:27 am
I wasn't referring to the method of measurement actually, but the fact that you had measured them and committed it to memory.
Unless of course you had only recently measured them of course.
:D
