Page 37 of 38
Re: The TRX900 Project kicks off
Posted: Tue Sep 26, 2017 10:31 am
by coxylaad
Does anyone have an old scrap TRX frame they dont want anymore? I want one to chop up
Posted: Tue Sep 26, 2017 11:11 am
YEP, but I aint posting it. Want 50 quid for it.
Posted: Tue Sep 26, 2017 11:13 am
by coxylaad
where abouts are you based these days mince? I cant keep up
Posted: Wed Sep 27, 2017 8:20 am
by Racer-unk
Best of Luck Coxylaad...give us hope
Posted: Thu Sep 28, 2017 9:29 am
coxylaad wrote:where abouts are you based these days mince? I cant keep up
Now back in West Sussex.
Posted: Thu Sep 28, 2017 9:49 am
by coxylaad
christ not very far away then
Posted: Thu Sep 28, 2017 4:08 pm
Just a mere `jaunt`, me n the old Donkey did 1,060 miles last weekend.
Posted: Thu Sep 28, 2017 10:27 pm
by coxylaad
well there's no going back now.
Popped down to York to pick this little lot up.
It looks like quite a large pile of stuff, but in many ways its more compact that the trx engine. its not as deep front to back by about 30mm, and its not as tall either. Means I should be able to make brackets up for it to fit.
Crucially though its just a fraction too wide at the cylinder head for it to fit between the lower frame tubes. Once I have got this last trackday out the way I will strip the bike back and see how it offers up. I am not totally confident with 'dressing the insides of the frame tube to clearance it. I may have to make a new bottom tube up on one side.
After specifcally asking for a none abs mt09 I now have a full setup for a yamaha tracer, which comes with ABS and traction control. neither of which I want. I am going to see if I can get it flash written out of the ecu.
other than that all good though, the engine is relatively unmarked and has 6600 miles on it.
Posted: Fri Sep 29, 2017 12:57 am
If you choose to modify the frame and chop and weld in a new bottom rail to mount it, Get a measurement parallel from the LHS engine mount position on the head to the drive sprocket centre.
Do the same on a trx motor as the 40mm offset you need to fit into the frame can work to an advantage on sprocket alignment on which bottom rail to replace.
Posted: Fri Sep 29, 2017 6:43 am
Pay a lot of money for that motor Coxy, 500 quid=ish?
Posted: Fri Sep 29, 2017 8:20 am
by coxylaad
yes cobba, the drive sprocket will govern where the engine sits in the frame.
Mince if you can get me an mt09 engine setup like that for 500 quid I'll have 3 of them please!
Posted: Tue Oct 03, 2017 2:08 pm
by SDN
My mate lunched his MT10 engine, reckons he got a used replacement engine for £1500, which I thought was good value - course he could have been lying
Posted: Tue Oct 03, 2017 2:14 pm
by SDN
Oh yes and by the way looking forward to seeing you shoe horn an MT09 engine into your TRX - good luck and keep us all posted!
Posted: Tue Oct 10, 2017 10:25 pm
by coxylaad
Last ever track session on the TRX in its current form.
it was a lot of fun
https://www.youtube.com/watch?v=YkMHnmdTLg4&t=
enjoy!
Posted: Wed Oct 11, 2017 11:23 am
by dandywarhol
Good one. Consistent lines!
Only using 3 gears (apart from moving off)? Have you considered downgearing it and using the upper ratios which are closer spaced? #just thinkin'
