4UN CDi
Glyn
4UN CDi
Post by Glyn » Thu Oct 19, 2006 6:41 pm
Hi all,
Just won a 4UN CDi unit on ebay for £10 and I wondered is it a straight swap for the restricted import version (4NX or something like). I seem to recall that it clears the rev restriction but do I need to do any more mods before firing it up? I have a Euro kph speedo I believe, as there is no hole in it for the wires to a restrictor and a bit of electronics taped up behind the fairing which I guess is the restrictor unit (my TRX tops out at 7000rpm in all gears) - sorry if this has been done before.
Glyn..
Fetch me the Fez of forgetfulness !
honkdawillydahonk
Post by honkdawillydahonk » Thu Oct 19, 2006 6:59 pm
No mods required. Just plug and play....
Glyn
Post by Glyn » Thu Oct 19, 2006 7:06 pm
Thanks Honk, I'll do it tomorrow.
Glyn..
rct
Post by rct » Sun Oct 29, 2006 8:06 pm
this is interesting for me as i have an inport but i also have the uk cdi unit sat it a box never used.
now i have never had the revs top out on me at all????
so how will i know if putting in the uk cdi will make any difference???
honkdawillydahonk
Post by honkdawillydahonk » Sun Oct 29, 2006 8:25 pm
rct wrote:this is interesting for me as i have an inport but i also have the uk cdi unit sat it a box never used.
Has it got an M-Max or similar box fitted? If not; will it go past 115MPH in top gear?
rct
Post by rct » Mon Oct 30, 2006 10:07 pm
sorry to sound dumb (but i just ride it then fix it) what is and where is a M-Max or similar box fitted????
soz honk but i gota know?
P.s. i do reacall going past 120mph from time to time.! :lol:
honkdawillydahonk
Post by honkdawillydahonk » Tue Oct 31, 2006 8:15 pm
M-Max make derestriction boxes (that fit in line between speedo and CDi, behind the clocks) But you won't need one if you've got a 4UN CDi....
rct
Post by rct » Tue Oct 31, 2006 8:33 pm
honkdawillydahonk wrote:M-Max make derestriction boxes (that fit in line between speedo and CDi, behind the clocks) But you won't need one if you've got a 4UN CDi....
in that case i might just fit it?
Glyn
No restrictions
Post by Glyn » Sat Nov 04, 2006 7:15 am
my 95 import would only rev to 7000 in any gear because someone had removed the restrictor from the speedo and taped it up behind the fairing. I have left this alone (I have no derestrictor fitted) and just fitted the 4UN, takes about 2 minutes if you don't drop one of the fixing screws into the the battery compartment ! Then it revs to the red no bother.
Glyn..
