Any feedback on Hyperpro Spring Kits
hammy
Post by hammy » Thu Sep 09, 2010 10:04 am
Hello guys, looking to get a little better on the front end, was looking at new springs and oil, has anyone got any views on the Hyperpro Spring Kits. Either just the front kit or the combi kit.;-
http://www.sportsbikeshop.co.uk/motorcy ... prod/44789
Thanks in advance, Hammy.
hammy
Re: Any feedback on Hyperpro Spring Kits
Post by hammy » Thu Sep 09, 2010 10:22 am
Sorry forgot to add its a 98 import Trx, and I'm only 11 stone dressed just in my pants. (No pictures enclosed).
Post by trixynut » Thu Sep 09, 2010 11:46 am
Personally I dont like progressive springs, which I think these are. Why do you want a harder spring rate when the forks are compressed?
If you've got an import, as you've probably realised, the springs may be softer than UK spec ones as the Japanese are all tiny.
A swap to UK springs and a fiddle with air gap and oil weight will make big improvements before splashing out ££ on kit like this, although the stadard TRX front end set up is not ideal even if its operating perfectly.
Someone will no doubt say "chuck a YZF or R1 front end at it" which is a good way to go, but costly.
I went for Ohlins springs. Cost about £75 from M&p and are longer (do away with the spacer tube at the top inside the forks) and this made the front end much better.
Otherwise, any suspension tuner will provide you with springs/oil to the right spec to suit your weight.
And please dont go riding just in your pants.
JW-TRX
Post by JW-TRX » Thu Sep 09, 2010 11:48 am
Post by Mincehead » Tue Sep 21, 2010 5:14 pm
If you`re buying I`ll have them. :wink: :lol:
Post by Tarwetijger » Tue Sep 21, 2010 7:41 pm
Hyperpro's are progressive indeed, but to my opinion there's nothing wrong with that, espacially for sporty street riding. I bought my bike originally fitted with hyperpro springs - back and front. The bike felt great with them, untill I started fiddling with UPSD forks and YZF rear shock. :roll:
Post by slow codger » Wed Sep 22, 2010 11:12 am
:twisted: 95 Japanese Import springs swapped for UK spec ones made a lot of difference! Mince if you want my Japanese ones you can have them, hope you've not got any loose fillings though!
Wombat
Forum Marsupial
Post by Wombat » Wed Sep 22, 2010 11:25 am
Can you still buy Hyperpro rear units for the Rex?
Post by Mincehead » Wed Sep 22, 2010 1:26 pm
Email them and ask Bob, they were of course behind the TRX `Troll` some piece of engineering.Here`s a picture of it for sale on Evilbay:
http://cgi.ebay.co.uk/YAMAHA-HYPERPRO-T ... 5634b2175a
I had a quick look through their listings and the complete shock didn`t come up, instead they list replacement springs front and back and steering damper kits. :wink:
Wombat
Forum Marsupial
Post by Wombat » Thu Jan 12, 2012 11:03 am
Hyperpro emulsion type shock YA08 - oab for TRX 850 is still available in Australia thru YSS @ $599
Richy
Post by Richy » Thu Jan 12, 2012 11:33 am
When the wife got her TRX it had Hyperpro for springs in it but as she is only about 10 stone the front end was a bit to hard so went back to standard which she is happy with, Hyperpro recomend a different grade and amount of oil, they will be up for sale when sort them out.
Post by fung » Fri Jan 13, 2012 10:55 am
[/quote]I went for Ohlins springs. Cost about £75 from M&p and are longer (do away with the spacer tube at the top inside the forks) and this made the front end much better.
[/quote]
what part number do you have for the ohlins?
Post by Con Rod » Fri Jan 13, 2012 1:25 pm
by the by, if anyone is cutting new spacers, the stock ones are 35.5mm in diameter....just a handy bit of info to have
