YZF750 swingarm - again
Posted: Sat Nov 14, 2009 11:54 am
by dandywarhol
I've looked in "search, can't find the awswer................ Can either a YZF750 or 750R swingarm fit straight into a TRX?
................and in case you ask why phuk....................the answers "because" :wink:
Re: YZF750 swingarm - again
Posted: Sat Nov 14, 2009 11:55 am
by Kayla
Yes, straight in but it's wider at the wheel end so if you're using the TRX wheel you'll need new spacers n stuff.
Posted: Sat Nov 14, 2009 12:32 pm
dandywarhol wrote:I've looked in "search, can't find the awswer................ Can either a YZF750 or 750R swingarm fit straight into a TRX?
Straight in but you´ll have to either customize spacers....offset sprocket or take down the sprocket carrier to line up with the front sprocket....
Posted: Sat Nov 14, 2009 2:07 pm
by dandywarhol
Thanks - So there's no difference in fitting the "R" or standard YZF750 one then? anyone know what the physical differences between the arms are?
Posted: Sat Nov 14, 2009 2:56 pm
by Kayla
Do you mean the 'SP' rather than 'R'? I think they're the same- it was only the works arms that were braced.
Posted: Sat Nov 14, 2009 3:34 pm
by G Beale
Lots of similar questions on this matter on the FZ750.com forum. Someone posted this link which I thought was useful.
http://homepage1.nifty.com/246/yam_sarm.htm
Note dimensions are not guaranteed as they have been submitted by various different people. Also note YZF dimensions at point A are said to be 256mm "without" end caps so I'm guessing "with" would take it up to 262mm as per TRX. :D
Posted: Sat Nov 14, 2009 4:28 pm
by dandywarhol
Yes, I meant the SP :oops: - great chart, thanks Graham
Posted: Sat Nov 14, 2009 8:52 pm
dandywarhol wrote:Yes, I meant the SP :oops: - great chart, thanks Graham
I have the SP....same same.....
Posted: Tue Mar 06, 2012 10:09 am
by schmiffee
G Beale wrote:Lots of similar questions on this matter on the FZ750.com forum. Someone posted this link which I thought was useful.
Not trying to dig up an old post, but this link is no longer active. Does anyone know where I could find the info again, or was someone really smart and copy this info before they removed it??
Posted: Tue Mar 06, 2012 11:27 am
by Kayla
You called?
http://suzume.yu-nagi.com/yam_sarm.htm
:D
Posted: Tue Mar 06, 2012 12:05 pm
by schmiffee
Kayla you CHAMPION!! :lol: :lol:
Posted: Tue Mar 06, 2012 12:11 pm
by alextrx850
i noticed that on fitting my YZF 750 rear swing arm , point A [the pivot diameter into the yolk] had the similar bearing end seals as the trx AND,..a spacer washer each end too.[which the trx didnt have]..as it came off the yzf ..it fitted into the trx ..yzf pivot bolt is needed as well from memory
a trx rear caliper can be retained, but a yzf carrier bracket is needed
rear disc is trx same as is the torque arm..
trx sprocket is turned over or inverted to have a three mm to line up with the drive sprocket.
a split link chain to pass through the reinforced part of the swing and trim a section of the upper reinforcing plate to allow an r6 shock to be fitted.
