Got the Thundercat forks fitted- at last!
Posted: Sun Jul 12, 2009 8:55 pm
by Kayla
Here's a few pics of the Thundercat forks fitted to my bike. It was pretty straightforward and the spacers were perfect (thanks Greg!).
'Scuse the mess
Mmm... adjusters
YZF750 mudguard looks a little Bodgitt & Scarper at the mo- nothing a few minutes with a heat gun won't sort but it'll do for now
You should be able to see the new spacers between the speedo drive and spacer and fork legs. Can't get the last 10mm of the front scrubbed in
Gratuitous FCR shot
Polishing nerds- Yes, my bike is scruffy but it works and it's great.
I had to bite the bullet and fit higher bars as my back is a bit knackered at the minute. Hopefully clip-on service will be resumed soon.
Re: Got the Thundercat forks fitted- at last!
Posted: Sun Jul 12, 2009 9:26 pm
by trixynut
Nicely done!
...and the only way you'll scrub in the last 10mm of a front is to low-side it!!
Posted: Sun Jul 12, 2009 9:54 pm
by G Beale
"YZF750 mudguard looks a little Bodgitt & Scarper at the mo- nothing a few minutes with a heat gun won't sort but it'll do for now
Kayla if you're refering to the bottom legs sticking out too much at the front then that's how they are. Got YZF one fitted to my FZR forks & it's the same as yours from the front, wider at the bottom.
Looks fine to me.
Posted: Mon Jul 13, 2009 2:49 am
Posted: Mon Jul 13, 2009 7:15 am
by Kayla
Thanks for the replies
Yep, I'm taking it the long way round to work today
The forks have compression and rebound and I think the springs are a higher rate than the standard TRX ones. The legs are the same length and I've got them set with 45mm showing above the top yoke. I just re-oiled the forks with 5wt (as standard T'cat) with the standard amount and they're set near enough standard on the adjusters so I've got a base to work from. New shock next!
Posted: Wed Jul 15, 2009 3:13 pm
by Trixz
Your comment:
I was about to ....
Ps.
1996 TRX850 import. UK cdi, dynoed at one million horsepower, upside down exhaust, wavy tyres, carbon fibre toilet seat, blah, blah, blah...
Posted: Wed Jul 15, 2009 6:21 pm
trixynut wrote:Nicely done!
he's not wrong (well, it's virtually impossible to scrub them to teh edges anyway)
nice work btw
Posted: Wed Jul 15, 2009 9:06 pm
by Kayla
Thanks all
I'm going to go back to the clip-ons as although the higher bars are more comfortable, there's not as much feel and they're a little too 'IAM' for my liking
I'll get some ally plate and make some plates to move the rearsets up and back too- in for a penny...
Posted: Fri Jul 17, 2009 8:26 am
by idl1975
phuk72 wrote:trixynut wrote:Nicely done!
nice work btw
Hey, I managed to scrub in the whole tyre on the right side...
...by _very_ nearly lowsiding it on a diesel-soaked roundabout.
Try it, it's fun!
Posted: Sat Jul 18, 2009 2:56 pm
by Kayla
The forks seem to work well and feel plusher and more composed than the TRX forks but that could just be down to having fresh oil in them. The stuff that came out of them was like water, only runnier. I'm pretty chuffed with how it's turned out.
Posted: Wed Aug 12, 2009 9:37 pm
by Tarwetijger
Ah, I just love the white color scheme.
So get that fender painted please
Posted: Mon Sep 07, 2009 10:38 pm
by amiciangelo
Posted: Wed Sep 09, 2009 2:30 am
by Kayla
Hiya,
All you need is the Thundercat forks as they fit straight into the TRX yokes. You need two spacers to go between the fork lowers and standard spacers. That's it! I'd advise you to measure your own spacers as every bike's different.
http://www.trx850.motomaniac.net/forum/ ... ers#p47576
Posted: Wed Sep 09, 2009 12:37 pm
by amiciangelo
Thanks for the reply, since you've already made the change, if you do not create problems, you can give me the steps to build the spacers?
(This is the axis of wheel spacers?)
Posted: Thu Sep 10, 2009 11:25 am
by Quan-Time
gratz on the mod.. Look good. Also like your vapor speedo thing.. Tiny = good.
