Alternative Front Fork Bottoms Mudguard
tbec407
Post by tbec407 » Sat Mar 28, 2009 6:31 pm
Just fitted FZR600R Fork Bottoms, Mudguard and spindle to to TRX fork tubes, new oils and seals. Look better than originals "imho"
Cheers Brad
steve speed
Re: Alternative Front Fork Bottoms Mudguard
Post by steve speed » Sat Mar 28, 2009 8:25 pm
looks good ,, a bit of a upside down look ,, and a lot more modern ,,,well done :D :D
Post by phuk72 » Sun Mar 29, 2009 9:52 am
why didn't you just fit the complete forks - they have 41mm legs don't they?
Kayla
Post by Kayla » Sun Mar 29, 2009 10:40 am
phuk72 wrote:why didn't you just fit the complete forks - they have 41mm legs don't they?
Maybe the legs were bent/rusted/generally knackered? Looks good though :D
tbec407
Post by tbec407 » Sun Mar 29, 2009 7:06 pm
No rebound damper adjustment on the FZR forks just preload
Brad
Post by Mincehead » Mon Mar 30, 2009 10:25 am
I like that,really nice look,well done. :wink:
G Beale
Post by G Beale » Sat Apr 25, 2009 12:32 pm
Brad
Forgive my ignorance here but do TRX forks have rebound adjustment then ? I ask as I've just bought/won a pair of foxeye forks which I intend to replace my TRX units with but would seem silly if they are inferior items ? I assumed they would be at least as good being the exact same age. :?
Kayla
Post by Kayla » Sat Apr 25, 2009 5:48 pm
Brad
Yes, the rebound adjuster is the screw inside the preload adjuster. Can be turned 'on' or 'off' :lol:
idl1975
Post by idl1975 » Sat Apr 25, 2009 7:34 pm
The four position adjustment on the fork tops is a combined compression and rebound damping adjustment, IIRC.
Brad
'04 Aprilia Tuono Fighter
'00 Scooby Sport Wagon
'76 TY250.
Post by Killerwhale » Sat Apr 25, 2009 7:39 pm
Compression on TRX fork is set by oil IIRC... :lol:
Kayla
Post by Kayla » Sun Apr 26, 2009 6:08 am
Killerwhale wrote:Compression on TRX fork is set by oil IIRC... :lol:
Yes. Preload and rebound only on the TRX.
G Beale
Post by G Beale » Sun Apr 26, 2009 12:18 pm
Ok thanks for replies (even the silly ones :lol: ). If these FZR forks come with less on them than the TRX ones I'm thinking there might be a way of using the best bits from both to make 1 good pair. My TRX tubes have some very minor pitting in the chrome just above the area of travel & I just bought a YZF front mudguard which I'm hoping will bolt to the FZR forks without too much butchering. [-o<
Post by dandywarhol » Mon Apr 27, 2009 12:08 am
Yep, pretty cheap and nasty, the squirting of oil through sharp holes in the damper rods just makes the oil break up quickly and gives harsh damping. Better to junk the damper rod system for a pair of luverly Race Tech Gold Valve emulators and get 2 stage compression damping to sweeten the ride - the rebound will just follow on anyway :lol:
BBB
Post by BBB » Thu Jun 25, 2009 9:17 pm
look good,
Is it just the fork sliders and wheel spindle you used or did you need the spacers etc...
Thanks
tbec407
Post by tbec407 » Fri Jun 26, 2009 4:15 pm
BBB wrote:look good,
Thanks
TRX speedo drive, not sure on the spacer think I used the fzr600rr one
