Sprocket supplier
idl1975
Sprocket supplier
Post by idl1975 » Thu Dec 11, 2008 1:02 pm
Having a bit of trouble finding online sources for TRX sprockets in other than the standard sizes. Or more precisely, a 16t front and a 39t alloy rear.
Easy enough to find standard sizes and/or a set of steel sprockets, but a bit harder to find anyone listing non-standard sizes.
Can anyone suggest a good supplier in the UK?
Also, does anyone think a basic 'o' ring 525 chain with a 8400lb tensile strength is inadequate for a 79hp TRX? I would have thought it would do fine, but would be interested in hearing any opinions.
'04 Aprilia Tuono Fighter
'00 Scooby Sport Wagon
'76 TY250.
Kayla
Re: Sprocket supplier
Post by Kayla » Thu Dec 11, 2008 1:08 pm
Daft question- have you tried B&C Express? They can normally machine one up from their stock of blanks pretty easily. I've not used them for TRX stuff yet mind, just TZR250 bits.
steve speed
Post by steve speed » Thu Dec 11, 2008 1:51 pm
as above B&C express will have all you want :D :D :D
idl1975
Post by idl1975 » Thu Dec 11, 2008 2:01 pm
steve speed wrote:as above B&C express will have all you want :D :D :D
Thanks guys - they don't list the TRX items on their website if I recall, but from the sounds of it they will be able to sort me out over the phone just fine.
:D
'76 TY250.
steve speed
Post by steve speed » Thu Dec 11, 2008 2:07 pm
they only list bikes that are currant production ,,but they will sort the trx
Post by trixynut » Thu Dec 11, 2008 2:48 pm
B&C are probably best as said, but can also try www.biketorqueracing.co.uk who are distributors in UK for Afam.
Post by phuk72 » Thu Dec 11, 2008 5:18 pm
+1 for B&C
Why 16/39 - more options with 17/42
idl1975
Post by idl1975 » Fri Dec 12, 2008 7:48 am
phuk72 wrote:+1 for B&C
Thanks for the advice.
I currently run 17 / 43 with steel sprockets. I like the ratio (130mph theoretical top speed is more than enough; lots more thrust), but am thinking it would be a good idea to replace the chain & sprockets because the bike was stored for 8 years with the current chain on it. I've been thinking that when replacing everything it would be a good idea to minimise the mass of the components. Hence I wanted to go with a smaller steel front and smaller alloy rear, which will also let me use a 110 link chain instead of 112. 16/39 raises the gearing a bit (135 mph theoretically, which I believe is closer to what a stock TRX can actually pull anyway, with a downhill slope and following wind...), but it's still lower than stock, and chain wrap should be OK.
What do you mean by more options though? Easier to get sprockets to fit, or something else?
'76 TY250.
Post by Quan-Time » Sun Dec 14, 2008 10:20 am
yes, also easier to change pitch of chain aswell if you desire. I personally run 520 chain, 17/41, renthal rear sprocket. Well, i think its 41, could have been 42, i cant remember.
idl1975
Post by idl1975 » Sun Dec 14, 2008 3:40 pm
Quan-Time wrote:yes, also easier to change pitch of chain aswell if you desire. I personally run 520 chain, 17/41, renthal rear sprocket. Well, i think its 41, could have been 42, i cant remember.
Thanks for clarifying that. I guess if you're having no trouble with 520, I won't worry too much about the strength of the 525 I've ordered. :)
'76 TY250.
