Well ive been trying for most of the week to sort some kind of underbike zaust
and failed , as far as i can tell it cant easily be done , 2 things because its a drysump bike u don't get the normal huge gap behind the sump that u normally get on wet sump bikes, which in simple terms means there's about 2/3's less room to play with
The second thing is the sodding suspension linkage, hanging down in the way all the time !!! no combination of pipework and cans that i could muster , and for anyone thats seen my garage that's alot!
i Even went as far as fabricating a totally bespoke back box that wrapped round the suspension linkage , but to get it so u had sufficient ground clearance means that it was so small it did little to no silencing , ive tried so many things radical and not and unless u want it so loud u might as well just be running the downpipes its not possible
the only reason is lack of space under the bike and anything that comes close to standard silencer size infringes on the ground clearance !
So the argument about lengths is irrelevant cos there just inst the room!
so i settled for this
oh and ignore the 2-1 section ... ahem i ran outa 1' 75th pipe so i had to bodge that up ..... got some on order
http://s250.photobucket.com/albums/gg26 ... 63a5b0.flv
thats a short vid of the can running , its sorta loud but ive heard worse
