replacement headlight ??
- steve speed
i need a good headlight for trixy ,,as you may or may not know mines a streetfighter so i need something with one h4 bulb that gives a good beam as i intend to fit a h.i.d light to this unit ,,,any ideas ????
- kookimonsta
Re: replacement headlight ??
you will be better getting something like a bandit one off ebay rather then a new pattern one from a shop. you will normally find pattern ones have plastic lenses and will melt with a high outpub bulb. plus something like new bandits and cb1300 headlights have clear glass with the beam pattern in the reflector so look the nuts too!
Have seen that MT-03 headlight is used on SF all over....steve speed wrote:i need a good headlight for trixy ,,as you may or may not know mines a streetfighter so i need something with one h4 bulb that gives a good beam as i intend to fit a h.i.d light to this unit ,,,any ideas ????
Looks similar to the newer FZ6............same sort of shape to the one you have, which does look good.
- steve speed
thanks chaps keep the ideas coming,, i was also thinking along the lines of the new fz1
A guy who SF his TRX on a Swedish forum looked at the Fz1 lamp first....but that was somwhere in the region of 5 times as expensive as the mt-03 one....steve speed wrote:thanks chaps keep the ideas coming,, i was also thinking along the lines of the new fz1![]()
- pwmotorsports
nowt wrong with dominator twin round lights give much better light output then stock trx light
- steve speed
apart from its got two bulbs and i only want onepwmotorsports wrote:nowt wrong with dominator twin round lights give much better light output then stock trx light
I can see that......twould be good.steve speed wrote:thanks chaps keep the ideas coming,, i was also thinking along the lines of the new fz1![]()
- pwmotorsports
They also come singlysteve speed wrote:apart from its got two bulbs and i only want onepwmotorsports wrote:nowt wrong with dominator twin round lights give much better light output then stock trx light
- steve speed
with one of those it would be like a pimple stuck on the front ,,,NO NO NO
- kookimonsta
- steve speed
iam leaning to the FZ6 if i can get one with a small bug screen,,,just got to find one now !!
- steve speed
just fitted the HID conversion .....wow its bright not much heat off it........ very impressed
