K&N pod filters...
K&N pod filters...
Post by Killerwhale » Wed Oct 10, 2007 5:20 pm
Anyone know wich pod filters that fit the vel stack adaptor 85-3000
...kinda wierd measure....2 7/16 inch....
steve speed
Re: K&N pod filters...
Post by steve speed » Wed Oct 10, 2007 6:22 pm
Killerwhale wrote:Anyone know wich pod filters that fit the vel stack adaptor 85-3000
or 62mm
Post by Killerwhale » Wed Oct 10, 2007 6:51 pm
or 62mm
So it´s 62mm....well....we got the metric system way back so..... :oops:
devlin
Post by devlin » Mon Nov 12, 2007 12:19 pm
Just having a look at getting some pod filters. Are the 85-3000 adapters the only ones that fit the TRX? What length filter will fit under the tank without the air box?
Post by Killerwhale » Mon Nov 12, 2007 12:22 pm
devlin wrote:Just having a look at getting some pod filters. Are the 85-3000 adapters the only ones that fit the TRX? What length filter will fit under the tank without the air box?
....this one is for keihin flatslides....so you know.
devlin
Post by devlin » Tue Nov 13, 2007 2:13 pm
Ahhh! Ok I'll just move along now....... nothing to see.
Post by youngy » Tue Nov 13, 2007 3:35 pm
I believe the filters for stock carbs are:
Flange: 55-59mm
Form: cylindric
Length: 102mm
Kedo part number is 91394. Price 78.50 euro for the pair plus post.
devlin
Post by devlin » Wed Nov 14, 2007 12:22 pm
cheers Martin
Post by phuk72 » Thu Nov 15, 2007 9:52 am
I wouldn't recommend the use of pod filters on the stock CV carbs.
devlin
Post by devlin » Thu Nov 15, 2007 10:40 am
I am listening....... why?
Post by phuk72 » Thu Nov 15, 2007 10:45 am
CV carbs like still air.
I'm not saying it will be a disaister but you may experience running problems at high speed and / or in high winds. You only have to think of the problems encounteretd by some people who have drilled holes in the airbox.
Also, a word of advice. If you do junk teh airbox, buy another filter to go over the end of the crank breather.
Post by Killerwhale » Thu Nov 15, 2007 10:50 am
phuk72 wrote: Also, a word of advice. If you do junk teh airbox, buy another filter to go over the end of the crank breather.
phuk, been thinking of that a bit...
The crank breather hose is also an oil out if something goes wrong isn´t it....and what happens if you stick a filter directly on there....?
Wouldn´t it be better to have an oil catch tank and then an air filter (like Max had on the 4hr run?
Post by youngy » Thu Nov 15, 2007 10:59 am
Trixz is getting on fine with his. Mine are on order.
Post by youngy » Thu Nov 15, 2007 11:00 am
Super Ten had this. You can do it. Makes no odds apart from mess if it blows oil out. And makes an extra 1 - 2 bhp when it's not restricted by the airbox.
Post by phuk72 » Thu Nov 15, 2007 1:02 pm
The filter just stops vapour spraying onto your nice clean engine and stops the breather hosing oil onto your wheel in the event of a mishap.
And yes, an oil catch tank would be / is a better solution (but I can't be arsed!)
