tdm barrels and trx head?
- greengoatchoker
hi all new here so be patient this has probably come up a hundred times already . but tdm lower engine and barrels so 900cc and six speed box with trx heads cams etc any advantage / problems ?
it's never finished
- Quan-Time
ill give you a tip.. tdm / trx heads are 100% identical. the difference is cams and valves. But for the sake of the arguement, valves in this case are so minor, its not worth looking into.
If you REALLY want 6psd + 900cc.. get a TDM900 motor, get some kent cams, get a PC3 computer, dyno tune it, your away..
EDIT
Turns out they aint identical.. i made a post with pics about this to clarify
EDIT
- philk
- Quan-Time
differences between TDM900 / TRX850 ?
obviously injection, and you get a 6th gear.. altho top end speed is the same. Power is also the same, just the torque curve changes.. This is because you can only pass a limited ammount of air thru 38mm holes, so carbie or injected, your still only able to suck thru certain CFM..
is that what you wanted to know ?
- philk
- philk
Yes JE do a sexy 927cc big bore for the tdm900 - £250
I want the rods, as i still want to rev the motor....£200 each
Liners no problem apparently...£400 a go
I have the carbs on order.
Got the Vee Two Cams
Gas flow is arranged for Xmas.
So hopefully by end of next year it'll be finished...
- Quan-Time
927 ? interesting. I wasnt aware they were doing it. Might have to investigade the barrels and what not. Seems quite large and wouldnt provide much wall thinkness.. Which means some heavy machining would be in order.
Basically, the TRX850 block is different to the TDM900 so you would have to source some barrels. Ill see if i cant get some measuring done on it..
As for the bore liner. i will say this once again YOU DONT NEED IT IF YOU HAVE THE CORRECT PISTONS AND RINGS. Im sick of ppl thinking its some damn voodoo that you need else the bike will instantly melt / burn more oil than fuel / whatever.
- honkdawillydahonk
- philk
- Quan-Time
yes to the above. apparently there is a 960 kit fer the 900 motor too, oil try and find out some more.honkdawillydahonk wrote:Don't TDM's run plated Ally barrels? If so the barrels will have to be bored out, re-plated and re-honed to suit the bigger pistons....phuk72 wrote:Ooh, do JE do big bore's for the TDM now? How you gonna get round the ceramic liner?
