will this fit my trx?
Posted: Thu Aug 02, 2007 9:49 pm
by dillthedog
item number 120145468496
Posted: Thu Aug 02, 2007 10:01 pm
by dillthedog
ort his HONDA VFR750 SINGLE SIDED BACK END
Posted: Fri Aug 03, 2007 8:48 am
Define fit
If you mean bolt straight on, then no
If you mean can it be made to fit, then yes.
Posted: Fri Aug 03, 2007 2:44 pm
by dillthedog
you have met me i am not built for delicate stuff would prefer bolt straight in
Posted: Mon Aug 06, 2007 2:24 am
by Quan-Time
then no. Modding is possible.. Ive played with a VFR800i swinger, and yes it will fit.. Yes its UBER heavy, no its not easy.
doesnt the trumpy single sided fit like, bolt in ? its fairly common (for a single side) but the most common is a YZF750 which is prolly the best "performance" upgrade you can get.. for bling factor, go for anything !!
Posted: Mon Aug 06, 2007 9:57 am
Quan-Time wrote:but the most common is a YZF750 which is prolly the best "performance" upgrade you can get.. for bling factor, go for anything !!
OK, you got me. How does bolting in a heavier swinging arm increase performance?
Posted: Mon Aug 06, 2007 7:46 pm
by PhatVR6
i doesn't
for the record, I also think they look awful
Posted: Mon Aug 06, 2007 9:40 pm
by dillthedog
i dont do track days ect so performance is not a major issue cosmeticly i like the look of a single sider but i definatly am not a engineer so maybe a yzf is my best option i am still building my garage so it will be a winter prodject including fitting my fcr,s frame respray bodywork respray and a good clean and polish
