Removeable rear fender (mudguard) for track days mod.
Posted: Fri Jan 07, 2005 5:28 am
by tz250w
Tired of going to the track with your REX and having to remove the street stuff on the rear and still having that ugly black fender sticking out (looks so out of place on the track... :oops: )?
This is what I do. Remove four bolts and unplug the harness to the tail light and turn signals. Then I'm done. Well sorta....
It requires you to first remove the entire fender (once, you'll never need to do this again) and cut it in half just before the trunk space. Attach two 90degree angle brackets to line up with the stock mounting points and that's it. You can leave the front portion on and have the battery, CDI unit, voltage regulator and fuel pump mounted up, still have plenty of splash protection and be able to pull off the rear assembly in a few minutes. Not only that, it makes the bike look "race sexy". :twisted:
Pictures should explain...
Posted: Tue Oct 04, 2005 11:22 pm
by Jojo
AARRRGGG! :shock:
Hi tz250w. :roll:
Your CDI is authentic or made by Over! :roll:
Posted: Wed Oct 05, 2005 12:30 am
by tz250w
Welcome Jojo! :D
Yes, it's made by OVER.
Posted: Wed Oct 05, 2005 12:42 am
by Jojo
:D
So you are lucky to have it!
I don't know what i'll give to have one! [-o<
But it work especially with FCR41, it's calculated for?
In France we can't find it.... ](*,)
:thumbup:
Posted: Wed Oct 05, 2005 1:11 am
by tz250w
OVER doesn't manufacture them now... :(
I had to get mine used on a Japanese auction. Yes, they are hard to find.
It works well with any carb. No TPS circuit...
I think you can modify the Euro model standard CDI to over specs though, have you heard of this?
Posted: Wed Oct 05, 2005 1:42 am
by Jojo
:wink: OK, I thought it was only made for FCR41!
I made the shunt on my CDI:
Image Image
And now it's better at low rythm, there less jerk and it's more quicly to go up to the higt rythm!(excuse me for my english :oops: )
:thumbup:
Posted: Wed Oct 05, 2005 2:16 am
by Sweeeeet
btw the second is mine :mrgreen: :twisted:
Posted: Wed Oct 05, 2005 2:41 am
by Jojo
Sure, mine is more clean! :lol:
This is mine:
See you on the french forum Sweeeeet! \:D/Image
