Rear shock
minus1
Rear shock
Post by minus1 » Sun Apr 12, 2020 10:37 pm
I am in the process of cleaning the rear shock and I noticed that the rubber bump stop is perished, is it possible to replace it yourself or is it a job for a specialist?
Re: Rear shock
Post by cobbadiggabuddyblooo » Mon Apr 13, 2020 7:52 am
Cost you about $300 for a full service and bump stop on the rear shock and will come up like new again , re-gassed and new oil if in Oz...
pbear62
Re: Rear shock
Post by pbear62 » Mon Apr 20, 2020 1:45 pm
The bump rubber on mine did the same thing years ago.
I was looking for a temporary fix as we were going away for a 2 day ride the next day - hunting through tubs of stuff in the shed I found the bump rubber off the top of a Ford Escort rear shock looked like it would work.
I cut a slit through the bush to enable it to fit around the shock shaft (the bush ID was a bit bigger than the original one but no problem with this). I managed to squeeze it between the spring coils & once it was slipped around the shaft I used a bit of superglue to make the bush a full circle again - job done!
I reckon this was about 5 years ago now - it's still in there & still working perfectly!
